3 members (baldeagle, SWEET, NJC), 43 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#176568 04/16/2005 4:42 PM
I've had my 54 3100 w/235 for 4yrs...never had a cooling problem or any leaks..it's originally a down south hot weather truck..anyway, was fixin to do a cooling system flush and looked at the radiator cap...14#?..everything i see in my books says 4#..anyone have a clue why it all works well with the cap i have, and should i change to a 4#? Sure would appreciate a response, gonna be headed to the parts store for some other things...thanks
#176569 04/16/2005 8:02 PM
Junior Member
Junior Member
My 53 has a presure relief valve in the upper radiator tank facing the engine. I've tried to pressurize the cooling system once with a pump up type of tool and could only get it to four pounds before it would release. I think that's typical. So the cap rating is probably not important.
I feel like I'm diagonally parked in a parallel universe.
#176570 04/16/2005 8:38 PM
I don't think that you want to use a 14 lb cap unless the book says so. I was under the impression that the Chev rad did not have the pressure relief valve.
1951 1 Ton Completed
#176571 04/16/2005 9:19 PM
Appreciate it..cap is old anyway, so probably just replace it with a new 4#..thanks
#176572 04/16/2005 10:13 PM
shopper I would go with a 4lb cap.the raditor is getting old and thin.something like old people.
dan-pa
#176573 04/16/2005 11:08 PM
Got that right...starting to feel a little old and thin myself...Old Fred sure runs good though, had a good gone through today and some new hubcaps...looks like tomorrow is a cruising day...supposed to rain, but my vacuum wipers work good when i remember to let up on the gas
#176574 04/17/2005 9:53 AM
Yup. Stay with a 4# cap, or you could wind up pushing water out of all the wrong places.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
