3 members (Otto Skorzeny, Reftys49, FAST55), 143 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#176509 12/08/2004 3:54 AM
Custom Title
Custom Title
How much spring arch are my front springs supposed to have on my early 50's 3/4 ton. I don't know the exact year of the chassis. Mine look just about flat..the center is maybe 2" lower than the ends. Is this normal?
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
#176510 12/09/2004 1:52 AM
Custom Title
Custom Title
Anyone?
49 Chevy 3600
65 Chevy K10
#176511 12/09/2004 3:06 AM
I
I Offline
Not normal as far as I can tell.
But I cant tell you what is.
I took my old ones to a spring shop and had them re-arched for 40$.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#176512 12/09/2004 5:00 AM
in2deep, is that $40 per spring? That's about what I paid.
#176513 12/09/2004 5:14 AM
Custom Title
Custom Title
Well, ok... So does rearching really work? I heard they just go flat again really quick. True/False?
49 Chevy 3600
65 Chevy K10
#176514 12/09/2004 5:16 PM
I
I Offline
I paid 40 for both. As in 40 dollars total.
(it was a cash job)
#176515 12/09/2004 7:09 PM
Normally, there should be about 3 or 3-1/2 inches between the rubber bump stop and the frame rail.Also, check out the shackles on the front,should be just over center towards the front of the truck.
#176516 12/11/2004 6:25 AM
On both of my half ton pick ups there seems to be no arch in the front spring at all. The rear are arched considerably without a load in the bed. I just think it is because of the weight of the motor.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#176517 12/11/2004 8:21 PM
South-
Most re-arching will involve re-tempering the metal, taking it up to temperature and re-forming the arch. If there are any flaws in your springs, they'll pop at high temp, forcing replacement.
Re-arching is on my to-do list for the '54 GMC that sits pretty low. Hope you have a spot nearby that can do a good job. The closest one for me is 80 miles each way. Worked well for my former S-10 and really made all the difference when you put a load in the bed.
#176518 12/11/2004 10:56 PM
I also hear a little Viagra with every fillup will do wonders for your truck's stance...
54 3100 with 235
62 flatbed dump C60 with 261
#176519 12/12/2004 3:51 AM
My old friend and mechanical mentor gave me instructions on "fixin'" a "flat" spring on the driver's side, front on the '54 I used to have. It was the poor boy's method.
I took the sping off of the truck, took it apart, put each leaf in a blacksmith's leg vise in a vertical postion with the spring held by one end then commenced to re-bend the leaves one by one with the help of a cheater pipe. I put in an extra leaf from a donar. It was one of the shorter, middle pieces.
This brought the height on that side even with the passenger side. It remained that way for the several years more that I drove the truck.
Jacques
Union, Justice and Confidence
#176520 12/13/2004 3:25 AM
V
V Offline
To directly answer your re-arching question , yes they _ALWAYS_ go flat agin in about two years top or less if you actually work the truck at all ~ I do lots and lots of spring work in our truckshop and we tried deveral different re-arching places , _all_ of them plain old _sucked_ new springs are only 2 X the price of re-arching and come with new bushings to boot .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
