8 members (Robert Crandall, Wayne67vert, Uncles51, kades51, Hotrod Lincoln, jay d, Hanks custodian, Rusty Heaps),
79
Mod | | | Forums66 Topics128,041 Posts1,055,480 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | How much spring arch are my front springs supposed to have on my early 50's 3/4 ton. I don't know the exact year of the chassis. Mine look just about flat..the center is maybe 2" lower than the ends. Is this normal?
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 |
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Not normal as far as I can tell. But I cant tell you what is. I took my old ones to a spring shop and had them re-arched for 40$. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | in2deep, is that $40 per spring? That's about what I paid. | | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | Well, ok... So does rearching really work? I heard they just go flat again really quick. True/False?
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | I paid 40 for both. As in 40 dollars total. (it was a cash job) | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Normally, there should be about 3 or 3-1/2 inches between the rubber bump stop and the frame rail.Also, check out the shackles on the front,should be just over center towards the front of the truck. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | On both of my half ton pick ups there seems to be no arch in the front spring at all. The rear are arched considerably without a load in the bed. I just think it is because of the weight of the motor. | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | South-
Most re-arching will involve re-tempering the metal, taking it up to temperature and re-forming the arch. If there are any flaws in your springs, they'll pop at high temp, forcing replacement.
Re-arching is on my to-do list for the '54 GMC that sits pretty low. Hope you have a spot nearby that can do a good job. The closest one for me is 80 miles each way. Worked well for my former S-10 and really made all the difference when you put a load in the bed. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I also hear a little Viagra with every fillup will do wonders for your truck's stance...
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | My old friend and mechanical mentor gave me instructions on "fixin'" a "flat" spring on the driver's side, front on the '54 I used to have. It was the poor boy's method. I took the sping off of the truck, took it apart, put each leaf in a blacksmith's leg vise in a vertical postion with the spring held by one end then commenced to re-bend the leaves one by one with the help of a cheater pipe. I put in an extra leaf from a donar. It was one of the shorter, middle pieces. This brought the height on that side even with the passenger side. It remained that way for the several years more that I drove the truck. Jacques
Union, Justice and Confidence
| | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | To directly answer your re-arching question , yes they _ALWAYS_ go flat agin in about two years top or less if you actually work the truck at all ~ I do lots and lots of spring work in our truckshop and we tried deveral different re-arching places , _all_ of them plain old _sucked_ new springs are only 2 X the price of re-arching and come with new bushings to boot .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
