5 members (TooMany2count, Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 101 guests, and 2 robots.
Topics128,052
Posts1,055,729
#176256 05/20/2005 3:13 PM
RT1
Offline
Hello all, Newbe here, I like the look of no vent windows. I have a 54 chevy as was wondering about eliminating the vent windows, and using windows from an older truck without vent windows will this work. Has anyone done this? Are all the doors the same? Or am I nuts. Don't answer that... R
Anonymous
Unregistered
Anonymous
Unregistered
RT1
I have investigated this for my 54 also. The easiest method appears to be to use an earlier model door but you will lose the pushbutton handle. I have seen it done such as http://www.heavensentconsulting.com/Bob/54_project_pics.htm but they do not seem to want to share the secret. Definately some fabrication involved to move the front window channel to the front.
If you do get it figured out let us know. I plan to retain the vent windows for now but install electric windows.
I'd like em for mine too, it's a cleaner look, and it would be the finishing touch on Da Maus. Older doors is the only way I've seen it done. What could be simpler?
And welcome to the Bolt RT1. (Done any arty stuff on the 54?) I'm pretty new here myself and already learned a heck of a lot. Some of it even about Stovebolts. grin
Christian
RT1: i believe 47-50 doors would fit on your truck,,but i think the door strikers would have to be changed,,(they changed them in 51),,So have at it... grin smile cool
When GM put in the vent windows they took away the cowl vent on the drivers side of the cab. These cabs can get hot and it is nice have "factory air" coming thru that vent. I have both versions on my trucks and I like them equally well.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
