| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | Hello all, Newbe here, I like the look of no vent windows. I have a 54 chevy as was wondering about eliminating the vent windows, and using windows from an older truck without vent windows will this work. Has anyone done this? Are all the doors the same? Or am I nuts. Don't answer that... R | | | | | | Anonymous Unregistered | | Anonymous Unregistered | RT1 I have investigated this for my 54 also. The easiest method appears to be to use an earlier model door but you will lose the pushbutton handle. I have seen it done such as http://www.heavensentconsulting.com/Bob/54_project_pics.htm but they do not seem to want to share the secret. Definately some fabrication involved to move the front window channel to the front. If you do get it figured out let us know. I plan to retain the vent windows for now but install electric windows. | | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | I'd like em for mine too, it's a cleaner look, and it would be the finishing touch on Da Maus. Older doors is the only way I've seen it done. What could be simpler? And welcome to the Bolt RT1. (Done any arty stuff on the 54?) I'm pretty new here myself and already learned a heck of a lot. Some of it even about Stovebolts. Christian | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | When GM put in the vent windows they took away the cowl vent on the drivers side of the cab. These cabs can get hot and it is nice have "factory air" coming thru that vent. I have both versions on my trucks and I like them equally well. | | |
