2 members (1955 1 Series, Otto Skorzeny), 159 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#174806 03/21/2005 5:47 AM
30 March 2004: Removed cab from 1954 GMC.
20 March 2005: Put it back on.
But it's only temporary until the body work is done. It looks strange with a cab on it
after it's been sitting there bare for a year. During that year I:
Had the frame sandblasted,
Gave it a coat of ZeroRust,
Painted it black,
Replaced the front crossmember someone had butchered to install a short motor,
Replaced a spring perch,
Installed new king pins,
Installed new tie rod,
Had the springs re-arched, front and rear,
Installed new shackles, pins and bushings in the springs,
Installed new disc brakes on front,
Installed new shoes, cylinders, retainers, springs, adjusters and cables on rear,
Installed new power dual master cylinder,
Built new brake lines,
Replaced rear end with one from a '55 first Chevy,
Rebuilt the differential with all new bearings and new ring and pinion,
Dis-assembled a rebuilt 248 from a '56 to put a motor mount plate behind the timing cover,
Installed rebuilt 248,
Installed rebuilt TH200-4R transmission,
Altered old rear mount crossmember for clearance,
Installed new rear crossmember for tranny mount,
Built side mounts for tranny adapter,
Cleaned and cleaned and cleaned some more old rusty parts,
Sweated, bled, cussed and spit.
Did I leave anything out? Probably. But the point is the chassis is essentially finished
and I'm fixin' to start on the body work. Maybe in another year I'll be driving.
It's looking great Cletis! Good luck on the rest of the build!
-Stephen
GO RANGERS grin
Photos Updated so check them out!
I see a rusty frame
I want to paint it black.
There's no more scaly brown
I'm going to paint it black.
That's a heck of a lot a work, Cletis. Good on ya. About 3 days ago, I saw a '54 GMC on the freeway close to my house. Real cool lookin' truck. I'm sure you can't wait for that day...
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
Cletis how did that cracked block experiment work?
Did you ever get the engine running?
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Cletis, hang in there, it all takes time. Until just a couple of weeks ago I was in the same boat you are. A finished frame but no body. Now after 2+ years I have the body parts back from the painter and I am putting things back together. Let me tell you it's worth the wait.
Good luck
Geroge
Cletis - You have provided INSPIRATION !!!
Nice job !
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
Good job c. Thanks for sharing with your webpage. I have a '50 GMC with a 228. Did you rebuild your motor or have it done? Was it hard to find new GMC motor parts?
Thanks, Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
Wow. In the same amount of time I purchased some parts which are in boxes in the basement.
Must feel good.
"Happiness equals reality minus expectations" - Tom Magliozzi
2 Offline
Cletis
What did you do after lunch? That sounds like a pretty busy morning for a Texan.
Wow, Cletis, how did you find time to go to Decatur? I enjoyed the day, maybe I can get some shopping pointers at the next swap meet. BTW, still considering the 700r4 or 2004r swap for my hydromatic. Any suggestions?
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
Looks like I got some 'splainin' to do.
Brian, the cracked block experiment was a failure. It didn't hold. I've been meaning to add a footnote to the web page but........
Buddy, I found the engine on Ebay already rebuilt. We had to go to northern Arkansas to get it but we made it a recreational trip and spent a couple days in Memphis before going to Mountain View. It was such a nice little town we spent a couple more days there.
235 Fat Fenders, after lunch I took a nap.
cgresham1212, I added a section in my 54 GMC site about the tranny install. I forgot to mention in my Email to you the rear crossmember had to be cut down. You asked about the cab clearing the transmission. We put the cab on to start the body work and the lip of the floorboard hole just touches the tranny case.
24601
CLetis
Good on ya -- you're doing better than me
4 July 2000 -- Took cab off '49 1.5-ton
26 March 2005 --- Cab still off '49 1.5-ton
grin
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Cletis has many talents, I will be glad when he gets the blue goose on the road,, looks like it wont be long..it will be a driver wont it?,,,Fred
Redryder pix
My Hotrod
cletis like the website. keep up the good work. trying to work on the boys 50 now with the weather break will be back in the barn. hope to have it on the road by may. he will do the touck up stuff after its in tx. so don't be surprised if he logs on and asks for some help i know he can get it from the masters on the site. thanks again..mike j
Drive with Pride. mike j
family pic
