| | | Forums66 Topics128,167 Posts1,057,096 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17421 02/19/2004 4:16 AM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Well it's taken me a while but I finally got the rear end out of my 77 GMC. I want to swap rear ends. There seems to be a few differences. One in particular is the spring mounts. On the 49, the axle mounts above the springs, while the axle for the 77 is mounted underneath the springs. How do I get around this? I want to leave the original springs in the 49. Or do I have to change them? If anyones knows where there is info on this, or any help would be greatly appreciated. Thanks.
kskt4 | | |
#17422 02/19/2004 6:56 AM | Joined: May 2003 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 27 | Check out some of the stovebolt links. I've seen a 47-53 rear end conversion kit, but I think you need to get new leafs too. If you are getting rid of any parts on your old rear end, I may be willing to make it worth your time.
1954 Chevy 3100 235 2 Yamaha YSR50's 05 Silverado crew 00 Yamaha TT-R125 Supermoto
#17423 02/19/2004 2:41 PM | Joined: Jul 2003 Posts: 33 Apprentice | | Apprentice Joined: Jul 2003 Posts: 33 | I have swaped the rear axle on my 59 apache for one from a 85 S10. The only thing I had to do was cut of the spring mount on my original axel and weld them on the new one. just make shure you take a lot of measurments to align it corectly. | | |
#17424 02/19/2004 4:24 PM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks guys, Been doing some reading. One thing I read says I have to make sure my pinion angle is correct. What exactly does he mean? And how do you calculate the angle?
Also. When I took the 49 rear end out, I broke the bolts that go through the center of the springs. Can those be changed?
ysrjunkie. I certainly will keep you in mind when I get it done. Are you in need of any other parts? When I bought the truck, it came with new drums and cylinders and parts for the huck system. I am upgrading to discs in the front so I won't be needing the hucks. Thanks.
kskt4 | | |
#17425 02/19/2004 4:34 PM | Joined: Jul 2003 Posts: 33 Apprentice | | Apprentice Joined: Jul 2003 Posts: 33 | No problem to swap the bolts, jusy make shure the hed will fit in the hole of the mount. A normal allen hed did the trick on chevy springs. For the pinion angle I used a adjustable meter for measuring horisontal surfaces(don`t know the english word) on a flat surface next to the pinion and made sure the mounts were horisontaly. The most importante thing is to make shure the axle does not go straight in, you want some movement in the x bearing between rear axle and axle from engine. | | |
#17426 02/19/2004 5:38 PM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks Ove, I'm gonna get at grinding off the mounts today.
kskt4 | | |
