| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, My truck did the same thing last winter too when she's cold trying to warm up, she'll sit there rocking side to side with a miss. :o Also while she's warmin up, she'll blow out this black splatter out the exhaust pipe, with some moisture. Right now there's a area of 2x4 feet on the driveway that's black.  it has accummilated over a few weeks.
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Valve stem seals? I get a little leakdown in #4 and sometimes get the miss/splatter you describe. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Oil spatter or unburnt gas?
Fred 52 3600 69 C-10
| | | | | Joined: May 2002 Posts: 8 Member | | Member Joined: May 2002 Posts: 8 | Could it be unburnt gas. Does it seem to smoke just a little when running. put your hand at the exhaust pipe then smell your hand does it smell like oil or gas Has the carb been rebuilt? Had the same thing happen to a f**d that I had. Rebuilt the carb and it ran better than when new | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I get black spatter out of mine when it is warming up and it is tuned perfectly. It's just the carbon in the exhaust getting mixed with water and shooting out the tailpipe. You might want to check your valve clearances since a lot of your problems seem to point to them being set too tight- low vacuum, low power when hot, miss. Either that or your ignition is needing some tuning.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, I had rebuilt the carb around last september. I'll have to check the moister + black stuff from the exhuast tomorrow. I'll get some pics posted too.
| | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | I'm with Josiah , you're describing classic tight valves symptoms . no one likes to do this important job so they al say " oh I checked them , they're fine " ~ every time I offer to bet $5.00 they're tight the story suddenly chages . Valve adjust , set dewll , set timing and it'll be fine .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
| | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, I checked the exhaust today, I watched the black splatter for a few minutes while the engine was warming up. As I watched the black splatter come out, it was in little chunks half the size of a BB gun BB. They were flat black when they were coming out, but when they hit the ground they turned into wet black dots. I also put my hand up to the exhaust pipe, and it smelled like fuel maybe a little rich?? I forgot to take a pic of the splatter on the ground, i'll try to get one up tomorrow. Many thanks, Chevyboy
| | | | | Joined: Jun 2002 Posts: 50 Member | | Member Joined: Jun 2002 Posts: 50 | My 235 does the same thing, as nate says its probably the valves but as nate also points out its a pain to check. Here's what I do, after it starts I push the choke in about half way, it smooths right out and stops smoking. Maybe mine is a different problem but it works. Just idles a little slower than full at choke but runs great. Good luck
If it ain't broke I ain't worked on it.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | They are really not too much of a pain to check, just pop off the valve cover and slide a feeler gauge in there. The rocker arms on the valves that are closed should show some clearance, click when rocked by hand even, if they don't you know they are way too tight.
