5 members (HandyAndy, dt235sd, Otto Skorzeny, UtahYork, klhansen), 40 guests, and 1 robot.
Topics128,053
Posts1,055,777
#173590 10/10/2004 12:45 PM
Junior Member
Junior Member
I just finished my 48 3/4 ton and at about 45-50 mph it has a bad shimmey.The tires are new and balanced,the kingpins are new and the rest of the front end seems tight.Any suggestions?Thanks
Joe Bruno
#173591 10/10/2004 1:48 PM
Moderator
Moderator
I had the same problem in my '67 Jeep and a full front end rebuild was financially not an option. One of those shock absorbers that bolts from the frame to the tie rod did the trick.
Probably not an option if you are looking for the root problem.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#173592 10/10/2004 4:47 PM
Did you do a proper alignment as per the shop manual?
54 3100 with 235
62 flatbed dump C60 with 261
#173593 10/10/2004 4:55 PM
Check the "preload" adjustment on the steering gear. With the steering centered, there should be NO free play in the steering wheel. Even a slight movement of the wheel should move the Pitman arm. If there's any slop at all, it will shimmy at highway speeds. The service manual outlines an adjustment procedure, or there are several shade tree methods that work pretty well. I use an inch-pound torque wrench on the steering wheel nut, with the Pitman arm disconnected so I'm turning only the gear assembly.
#173594 10/10/2004 5:30 PM
Riding in the Passing Lane
I like to use a steering stabilizer like Bradb
was refering to on these straight axle trucks.
They are available at parts stores in a kit.
It seems like if the shimmy comes & goes at
certain speeds there is something wrong with
the wheel balance or out of round. smile
1972 Chevy c10 Cheyenne Super
#173595 10/10/2004 5:47 PM
On beam front axle vehicles, lack of castor usually causes a shimmy at moderate speeds.Are the castor shims in place between the front axle and spring? If so, is the axle tilted backwards,the thick part of the shim to the rear?I have found some need more castor, especially if the rear end is higher than the front.The factory says about 1-2 degrees,a 4 degree shim often makes a improvement in steering. Too much castor can cause it's own problems,like hard steering and maybe a shimmy like too litle castor
#173596 10/15/2004 1:34 AM
I remember about 40 years ago or more I knew of a truck like that. No one could find the problem. Even front end shops. It was a nearly new Ford. The agency could'nt fix it. Somebody finaly decided the front axle was put in backwards at the factory. Funny how something like that will stick in your mind. Dont ask me what happend yesterday.
I like old trucks
#173597 10/15/2004 3:22 AM
I had one today. A car had probably 2 cans of old "Fix-a-Flat" that didn't set-up. You can balance that tire all day and not get it true. Sure had our new kid tech confused for a while. Also had a truck tire full of water and a flat spot from sitting that you couldn't drive without your mouth open.
Weirder thing can happen,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#173598 10/15/2004 12:30 PM
Junior Member
Junior Member
Thanks for the tips.Turned out to be a bad tire and the toe in was way out.Drove it home from the front end shop with only 1 hand on the wheel-what a pleasure!!!!!!!!Keep em rollin
Joe Bruno
#173599 10/15/2004 6:52 PM
Glad you got it fixed, how does it drove with no-hands on the steering wheel...Fred
Redryder pix
My Hotrod
