7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 2 Junior Member | | Junior Member Joined: Oct 2002 Posts: 2 | I am rebuilding a 57BBW swb chevy and I need a rear end. I would like to know if anybody knows what the rear end rato and width is for the late modle 1999's to 2000 chevy caprice classic's and all the GM cars like it. Maby the Impala SS same year The 57 rear end was 62" brake to brake. Thanks for the help. [email protected] | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think they stopped making the Caprice/Impala in 1996. Scott | | | | | Joined: Apr 2005 Posts: 7 Junior Member | | Junior Member Joined: Apr 2005 Posts: 7 | I too am wondering the same thing about late model rear ends | | | | | Joined: Jan 2005 Posts: 14 Junior Member | | Junior Member Joined: Jan 2005 Posts: 14 | hey gene try this it covers a lot http://www.chevytrucks.org/tech/rear_ends.htm http://www.chevytrucks.org/tech/ifs&rearend.htm this has some good info. the 55-59 trucks are closer to 61 1/2" wide. caprice/cop car 10 bolt is 62" 3.08 and 3.42 with positraction is common. i am working on a 56 stepside. 71-81 camero trans am seem to be one of the most common swapped rearends it is real close in factory width after varifiying for myself. hope this helps some. | | | | | Joined: Oct 2002 Posts: 2 Junior Member | | Junior Member Joined: Oct 2002 Posts: 2 | Thanks newbie 56: I was not sure what year the caprice/impala ss was made I knew GM put some big engines in them and usually with a big engine GM puts a high rato rear end. They will have disk brakes and be less than 20 years old. 57 swb bbw 59 lwb sbw [email protected] | | | | | Joined: Jan 2005 Posts: 14 Junior Member | | Junior Member Joined: Jan 2005 Posts: 14 | no problem gene i just helped a good friend swap a caprice rear disc brakes on the 8.2" rear in his 66 chevelle. | | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | The (350ci) Caprices had a 2.93, the Impalas had a 3.07.
The Caprices had disc/drum, the Impala had discs all around, and the front discs were bigger than the Caprice. That's why they had 16" wheels.
The Impala SS based on the big Caprice was only made from 94 to 96. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You could get a Caprice equipped the same as an Impala, you'll have to get a cop car though, Scott | | |
