0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
I have a question:
Who knows what the little curved 3” piece of metal, spot welded in the middle of the fire wall, engine side, is for? I seen other trucks with it but never seen it being used.
Got an idea?
One more question, since that one will be easy for someone.
My truck was a basket case when I got it, and I can’t find the kick panels that go under the dash, by the floor, by the door. Could they have been cardboard and now disintegrated? Or are they metal and I just don’t have them any more?
Thanks for the help!!!
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
OK Kevin I'll take a stab at this one. Your kick pannels were cardboard. You can make new ones out of metal or get the cardboard ones from any of the vendors.
Now as for the curved piece of metal on the fire wall I'm not sure, but you might be looking at the cover for the drain for the cowel vent. If thats the case there should be a metal tube on the inside of the fire wall and one from the drain hole in the grove of the cowel vent. These two metal pipes are connected together with a short piece of hose.
Hope this helps.
George
George, I have seen the kick panels in Jim Carters catalog, but did't know if they were cardboard. Thanks!
When I get home I will look under the curved thingy. That might be what that thing is for, to keep moisture off the engine? or to hold a drain line?
Anyway, thanks for the help.
Regards, Kevin
Are you sure your truck came with kick panels? Factory '51s did not come with them. I can get them, but they are not a stock item. Cecil........
OK, I took a look at the curved piece a little better and sure enough there is a hole just above, behind it. The hole could most diffently be for a drain hose for the vent.
So is the curved piece to cover the hose or to hold the hose? still a mystery to me.
I'm real sure the truck has kick panels because there is a small flange (about a 1/4" high) at the floorboard that looks like it is for retaining the kick panels.
Thanks for the input guys!
Regards, Kevin
The curved piece is a deflector to divert the water off to the side so it doesn't drain from the cowl vent right onto the valve cover.
To be long remembered as he's cruising in
The Passing Lane
Berry, I knew you would know. You know '40s better than anyone I know.
Thanks!
Regards, Kevin
