3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 15 New Guy | | New Guy Joined: Oct 2004 Posts: 15 | Does anyone know how difficult it might be to change my 46 Chevy 2 ton to something smaller. I'm considering swapping out the front axle and rearend for a later model 3/4 or 1 ton. I was thinking that if I could go with something in the 50's that it would be relatively easy to do. I helped a friend change a 51 3/4 ton Chevy to 1/2 ton. So I figured it would be close to the same process.
1946 Chevy Flatbed 2 Ton Truck 1950 Chevy 3100 5 Window Cab P/U 1968 Chevy CST 1972 Chevy Fleetside Longbed 1992 Chevy Scottsdale Ext Cab 2000 GMC Sierra Ext Cab | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | You wanna change a '46 2 ton into a 50's 3/4 ton??
I'm no pro, but some of the obvious things on your list aside from some serious frame modification would be a whole new front clip,
If you really want a smaller rig, why not just sell the '46 and buy a smaller truck.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | That's what I was thinking. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Measure the height of the frame rails compared to those on a half ton. I don't know the numbers on Art Deco trucks, but on Advance Design trucks the difference is at least a couple inches.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
