4 members (klhansen, Otto Skorzeny, Wally / Montana, DadsFirstPickup), 153 guests, and 5 robots.
Topics128,077
Posts1,056,017
Members48,433
#172327 05/13/2005 4:02 AM
Does anyone have any pictures showing how to change (put) a new gasket in the cowl vent?
Do you have to remove the door or what? Any info
would be appriciated. Thanks
#172328 05/13/2005 4:58 AM
W Online: Content
It was a while ago but I think I removed the door. I know I used contact cement on the gasket and the metal. It hasn't leaked.
Say, a Stovebolter named Tommmy is also from Metairie. My wife and I went to one of your Mardi Gras parades several years ago. Good nice family fun!!
#172329 05/13/2005 2:25 PM
Thanks Wally, Don't know Tommy but your right,
it's a fun time a Mardi Gras (IN METAIRIE) not
New Orleans. LOL I was hoping someone had some
pictures of puting this gasket in the cowl. Thanks ED
#172330 05/13/2005 3:20 PM
i just opened the cowl vent door and put the gasket in place... i didnt glue it tho, so it fell out... now it's in a box on the shelf somewhere.
Another quality post.
Real Trucks Rattle
#172331 05/13/2005 8:47 PM
LOL that should help keep the water out!!! I know
someone has pictures of how to do this job. HELP
#172332 05/14/2005 3:12 AM
I don't have pictures and I don't think you will find a picture because it is that easy. You should be able to reach in with a pair of neddle nose plyers and pull the old one out without disassembly
#172333 05/15/2005 2:00 AM
its easy as mentioned but I found that the "rubber" gasket doesn't "settle" like the cork gaskets and actually keeps the vent "up" a little. Or it could just be that the parts house sent me the wrong one or it is thicker than its suppose to be??? Either way its easy....If I remember(?) there is a little drain hose that keeps any water from draining into the cab. Be sure its in place.
#172334 05/15/2005 3:27 AM
Thanks, I bought a rubber one from American Classic,
hope it fits right. I also bought a new drain hose.
#172335 05/15/2005 9:31 PM
I dd not remove the door just cleaned out remanents of the old one. I used weather strip adhesive to hold it in. Actually I use weather strip adhesive for a lot of gasket work.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
