3 members (wilbur53, 2 invisible), 71 guests, and 3 robots.
Topics128,109
Posts1,056,572
Members48,448
#171889 04/26/2005 5:00 AM
Anonymous
Unregistered
Anonymous
Unregistered
So I found out why my cab in my 64 was always smelling like gas. On the bottom corner on the driver side, you can watch it drip. It's really leaking quite bad. Is their a product like "Radiator Stop Leak" for gas tanks? Is their a common tank I can fit under the bed realatively easily? Or any other tips or ideas anybody has will be greatly accepted. Thanks much!
#171891 04/26/2005 6:06 AM
Junior Member
Junior Member
When we lived in Michigan my dad bought a 1976 Caprice station wagon with loads of rust as a winter beater. The gas tank had the same sort of leak you described, so he slapped on some duct tape really quickly and sprayed a generous amount of undercoating on it. It never leaked after that, but I wouldn't suggest doing that especially inside the cab. Eastwood has some products that clean the rust out of gas tanks, etch the surface as a prep, and then coat the inside to seal off pinhole rust. I don't remember the exact products, but I'd give their site a look if you want to keep the tank inside the cab. Here's a link to a guy using it on his Ford truck: http://fordification.com/my67-p36.htm
#171892 04/26/2005 2:02 PM
If you plan to keep the tank in the cab, I suggest replacing the tank. There are sources that sell OEM or reproductions for your '64. Try chevyduty.com and LMCtruck.com. If you plan to relocate between the rear frame rails, Classic Industries, Classic Performance Products and several others sell the custom fabricated stainless steel or aluminum tanks, sending units, filler assemblies and associated hardware. I am in the process of doing the swap on my 1966 C-10. Classic Trucks has a tech article on their website, as well. You can determine the ease of installation by reading the tech article. CPP also has a play-by-play tech article on this swap that is very informative.
#171893 04/26/2005 2:49 PM
I had the same thing happen to my 1966 C-30. Until I could get another tank, I patched it with a product available at most parts stores. I had to remove the tank, but it was very easy, as long as there is not much fuel in it.
I hope you are not a smoker! eek
Doug 57.
#171894 04/30/2005 10:22 PM
Anonymous
Unregistered
Anonymous
Unregistered
haha nope, i'm not a smoker.
Update: I removed the tank and brought it to a radiator shop. They cleaned it, and welded up the worn-out spot. They did a real good job. I have to put it in. Meanwhile I took the tank from my 60 and put it in. But now its done. I also figured out my gas guage problem while it was out, it was just that the PO had played around with it and the two wires were just backwards. thanks for all the replies!!
#171895 05/01/2005 1:17 AM
The Model A I restored had a few pin holes in it. The All Ford parts book I had carries a gas tank sealer that works rill well. I dont remember what it is called.
#171896 05/01/2005 11:44 AM
Socket Breaker
Socket Breaker
For the record, I think por-15 has a gas tank sealing product... other companies have similiar products.
I have not used them myself, but I have read of instances where other folks ont he 'botl have used them.
-W
