| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | Question, I have a 1954 one ton GMC, 248 engine. It starts and runs good except when it sits a while the gas runs back down from the carb and it wont start untill I crank it enough to get the gas back up.Is the fuel pump supposed to have a back flow valve in it? Do they make an inline filter with a back flow valve in it? Any sugestions?
I like old trucks
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Are you sayin' it syphons back thru the needle and seat in the float bowl? | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | No the gas stays in the float bowl but it wont run long enough on that to pull the gas up from where ever it has drained down to. Some times it will but most of the time it wont.
I like old trucks
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Put a loop in the fuel line or an electric pump
There should be a check valve in the pump
The new fuel is really hard on pumps | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | Thanks, I have'nt replaced the fuel pump because the one on it pumps ok. I think it had this problem long before I got because I found a can of ether in the glove box. I will spend the bucks to replace the pump but I was'nt sure if I was going the right way and I hate to just start changing parts to find the problem.
I like old trucks
