Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (cmayna, baldeagle, TooMany2count), 62 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#171624 11/18/2004 7:11 AM
Junior Member
Junior Member
' Offline
Trying to get my wipers hooked up. below the carb on the manifold is a vacuum port that the PO took the vacuum line loose and plugged the hole with a piece of wood. I am looking for a fitting to put back in the hole so I can hook the vacuum line back up. I have been everywhere looking for the fitting but can't find one that small.
The hole in the manifold is 1/4" accross.
Any ideas??
#171625 11/18/2004 7:51 AM
brass pipe fitting from a plumbing supply place - what's in mine grin
#171626 11/18/2004 3:02 PM
Junior Member
Junior Member
' Offline
I have been to 3 plumbing supply houses and the smallest fittings they have are with 1/4" inside dimension which makes the outside dimensioon 3/8".
If I can't find the correct size is there another place the line can be hooked up?
#171627 11/18/2004 3:15 PM
I ran into a similar problem the other day and went to my local hydraulic supply. I don't know if "Fluid Connectors" has a site but their phone number is 503-370-4454
#171628 11/18/2004 6:50 PM
Sounds like 1/8" pipe fitting. Try a real hardware store.
Fred
52 3600
69 C-10
#171629 11/18/2004 10:35 PM
Riding in the Passing Lane
I believe it,s 1/4 pipe thread. A parts store
should have a fitting with a nipple to hook the
vacuum hose to. If the fittng is for 1/8 pipe
thread use a reducer bushing. smile
1972 Chevy c10 Cheyenne Super
#171630 11/19/2004 11:49 AM
It sure sounds like a 1/8 pipe.Did you ever think about drilling and tapping it to a larger size?
#171631 11/19/2004 10:23 PM
My local Lowes has 1/8" pipe fittings in the drawer.
Ace Hardware usually has them too. They are used for ice maker lines.
Paint & Body Shop moderator
#171632 11/23/2004 6:13 AM
Junior Member
Junior Member
' Offline
Found out that this was a press in fitting made by GM. They don't make them anymore. Went to my old place of employment and one of the machinist is making me one.
Thanks for the reply's.
Tony
#171633 11/23/2004 9:30 PM
And that's in you 50 4400? All that I've seen were threaded, mine has 1/2" pipe thread. If you don't get one made, it wouldn't take much to thread the hole.
Fred
52 3600
69 C-10
