1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 35 Junior Member | | Junior Member Joined: Apr 2004 Posts: 35 | Trying to get my wipers hooked up. below the carb on the manifold is a vacuum port that the PO took the vacuum line loose and plugged the hole with a piece of wood. I am looking for a fitting to put back in the hole so I can hook the vacuum line back up. I have been everywhere looking for the fitting but can't find one that small. The hole in the manifold is 1/4" accross. Any ideas?? Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | brass pipe fitting from a plumbing supply place - what's in mine Bill | | | | | Joined: Apr 2004 Posts: 35 Junior Member | | Junior Member Joined: Apr 2004 Posts: 35 | I have been to 3 plumbing supply houses and the smallest fittings they have are with 1/4" inside dimension which makes the outside dimensioon 3/8". If I can't find the correct size is there another place the line can be hooked up? Thanks | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I ran into a similar problem the other day and went to my local hydraulic supply. I don't know if "Fluid Connectors" has a site but their phone number is 503-370-4454 | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sounds like 1/8" pipe fitting. Try a real hardware store.
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe it,s 1/4 pipe thread. A parts store should have a fitting with a nipple to hook the vacuum hose to. If the fittng is for 1/8 pipe thread use a reducer bushing.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | It sure sounds like a 1/8 pipe.Did you ever think about drilling and tapping it to a larger size? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My local Lowes has 1/8" pipe fittings in the drawer.
Ace Hardware usually has them too. They are used for ice maker lines.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2004 Posts: 35 Junior Member | | Junior Member Joined: Apr 2004 Posts: 35 | Found out that this was a press in fitting made by GM. They don't make them anymore. Went to my old place of employment and one of the machinist is making me one. Thanks for the reply's. Tony | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | And that's in you 50 4400? All that I've seen were threaded, mine has 1/2" pipe thread. If you don't get one made, it wouldn't take much to thread the hole.
