6 members (diseasel, Otto Skorzeny, Wayne67vert, klhansen, MickeyP, Jims46), 109 guests, and 1 robot.
Topics128,034
Posts1,055,552
#169830 05/24/2005 8:52 PM
Needed to close the bed roll on the old Chevy. I know that stainless and chrome plugs are available but decided to make my own. I used a
1 5/8" rubber expansion plug, the ones you use in frost plug holes. They come with a big washer and a nut so you can crank it up tight. I reversed the washer to hide the stamping, placed a stainless fender washer over that, placed it in the roll and tightened it up with a stainless acorn nut after tossing the cad plated nut. Looks really neat, fits tight and only cost me about $5 each.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#169831 05/24/2005 8:57 PM
Got my chrome bed plugs from Chevy Duty for $3.95pr, massaged the hole a little to get it round, added a little blue silicone on the inside, and snapped them it...they look great
#169832 05/24/2005 9:21 PM
excuse me but what is a frost plug hole? I wonder if a half-dollar would fit it, I have the metal ones in mine but may get me some of those brake light ones,,,Fred
Redryder pix
My Hotrod
#169833 05/24/2005 9:44 PM
Got mine at Lowe's. Go to the section where nails and screws are. Look for the area where all the cardboard pull out drawers are and look for the "sinkhole" plugs. Think that 1 1/2" was the size I got. May have to bend out some of the tabs to match the unround bed hole but it'll stay in. Cheapo and they last a long time.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#169834 05/24/2005 10:35 PM
Surely you jest, joker! Frost plugs in engine blocks for us northerners where it can get cold. The frost plug will give before the block does if the water freezes in it. Had one go years back under the exhaust manifold of a SBC and I put one of those rubber expansion plugs in it and it is still dry. The tail lights in the end roll are a good idea. I've seen them on a few trucks and they make a big difference saftey- wise.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#169835 05/24/2005 11:03 PM
So when you're redoing your bed, how do you clean / prime the area inside the bed roll, to keep it from rusting out?
Or do you just fill the tube with dessicant before installing these plugs?
Cheers,
mark.
#169836 05/24/2005 11:20 PM
olblu49, I understand,,,what we call freeze plugs,thanks ,,,,,Fred
Redryder pix
My Hotrod
#169837 05/25/2005 4:21 PM
51 KY 3100 the bed is done and I think the roll does not go completely around. There is a a gap where air can get in. The plugs I made can be removed in a few seconds if need be. As far as rust prooofing goes, one trick we use on float planes in the motor mount (which is a many tubed structure like a birdcage) is to drill small holes and pour in LPS oil. We plug the holes and then shake, twist, roll the unit so the oil goes into all the tubes. We drain it and replug the holes. As these are flown mainly in salt water, the trick works very well.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#169838 05/25/2005 8:49 PM
1 Offline
theres some company that makes bed roll plugs that are lights. i think im going to do that actually when i get to the process of buying a new bed and all that.
63 Chevrolet Short Fleetside
64 Chevrolet Long Stepside
http://community.webshots.com/user/64stepside
#169839 05/25/2005 8:51 PM
1 Offline
its www.pros-pick.com actually i jsut remembered
#169840 05/25/2005 9:35 PM
Check out Alan Horvath's website, he put the LED bedroll brake lights in. Looks pretty cool.
See this link;
Alan\'s LED Lights
Chris
Chris 1955FirstSeries
#169841 05/28/2005 10:09 PM
1 Offline
yea he got them from the link i put in my other post
#169842 05/29/2005 4:32 AM
grin
Hey - do I feel g-o-o-d!!
There is somebody with a name longer than mine!
:p
A BIG HOWDY from 6cylindersovertexas to:
1964BowtieCrazyStepside!
eek
#169843 05/29/2005 6:43 PM
1 Offline
hahahhaha thanks yea everyone had already taken the good names so i was like meh what the hell ill just make it long haha.
