2 members (Otto Skorzeny, 1 invisible), 92 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#169358 02/22/2005 8:05 PM
Has anyone ever tried that "Herculiner" bed liner. You do it yourself and save several hundered dollars, even though you don't get a professional to do it. I'm thinking about it, but I don't know. it claims that it doesn't chip, flake, and all that, but I want to be sure this stuff is really good. i'd like a RHINOlining, but that's crazy expensive. Any input? Thanks
GO RANGERS grin
Photos Updated so check them out!
#169359 02/23/2005 12:02 AM
I used it on a Jeep tub. I wasn't that happy with it. It does not handle gouges or abrasions very well. It tends to peel when it does let loose. I followed their instructions exactly. The only thing that I liked about it was that it was easy to patch and apply. The real, pro applied stuff is worth the extra money. The Herculiner is not at all the same product.
Paint & Body Shop moderator
#169360 02/23/2005 12:14 AM
Thanks for the tip! I think I might save up and go with the more expensive RHINO lining
GO RANGERS grin
#169361 02/23/2005 3:46 AM
Junior Member
Junior Member
I have rhinolining in my 99 chevy 1/2 ton. It's color matched and has been through hell and back and still looks great.
Scott
#169362 02/23/2005 3:47 AM
I used it on a truck bed, did OK for a while, then started peeling under any kind of abrasion. This was on a freshly sandblasted surface. Big disappointment.Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#169363 02/23/2005 2:28 PM
I was thinking about doing my whole truck with that bed liner, but it sounds like more has not stuck than stuck.
#169364 02/27/2005 5:22 PM
I used a product called Gator Gaurd truck bedliner and sprayed it over scuffed epoxy primer and it seams to be very durable. I used it on the inner fenders,inner cab and other parts. I had my running boards done profesoinally,which were widened and the cost $250 to have done. A truck bed cost $500 . Have a look here.
http://pg.photos.yahoo.com/ph/sublime589/album?.dir=3452&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/sublime589/my_photos
