9 members (Cosmo, Samantha, Otto Skorzeny, Brian Moore, Jims46, Ponchogl, moparguy, KEVINSKI, 55shaker),
83
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Has anyone ever tried that "Herculiner" bed liner. You do it yourself and save several hundered dollars, even though you don't get a professional to do it. I'm thinking about it, but I don't know. it claims that it doesn't chip, flake, and all that, but I want to be sure this stuff is really good. i'd like a RHINOlining, but that's crazy expensive. Any input? Thanks | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I used it on a Jeep tub. I wasn't that happy with it. It does not handle gouges or abrasions very well. It tends to peel when it does let loose. I followed their instructions exactly. The only thing that I liked about it was that it was easy to patch and apply. The real, pro applied stuff is worth the extra money. The Herculiner is not at all the same product.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Thanks for the tip! I think I might save up and go with the more expensive RHINO lining | | | | | Joined: Feb 2005 Posts: 13 Junior Member | | Junior Member Joined: Feb 2005 Posts: 13 | I have rhinolining in my 99 chevy 1/2 ton. It's color matched and has been through hell and back and still looks great.
Scott | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used it on a truck bed, did OK for a while, then started peeling under any kind of abrasion. This was on a freshly sandblasted surface. Big disappointment.Brian | | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | I was thinking about doing my whole truck with that bed liner, but it sounds like more has not stuck than stuck. | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | I used a product called Gator Gaurd truck bedliner and sprayed it over scuffed epoxy primer and it seams to be very durable. I used it on the inner fenders,inner cab and other parts. I had my running boards done profesoinally,which were widened and the cost $250 to have done. A truck bed cost $500 . Have a look here. http://pg.photos.yahoo.com/ph/sublime589/album?.dir=3452&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/sublime589/my_photos | | |
