3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
I have to cut about a 4ft run of approx 5/8" cast iron ... need some suggestions on the best way ... I have zip wheels (big and small), actylene, again large and small, recip saws etc. Any and all suggestions would be really appreciated.
Acetyline is definitely out- - - -all it will do is melt a big, sloppy groove. The oxygen jet doesn't cut cast at all. I'd suggest getting a gas-engined cutoff tool, the thing that looks like a chainsaw, but uses a big abrasive wheel. With that distance and thickness to cut, you'll go through several wheels, but you'll get a clean, relatively narrow groove. If it's any of my business, just what are you trying to cut?
:confused: :confused: :confused:
Take it to a plumbing supply place that can cut cast iron pipe. The same machine should be able to cut it for you and they shouldn't charge much. I went to one to have some big pipe cut before.
54 3100 with 235
62 flatbed dump C60 with 261
I'm too cheap to pay someone to do it for me... go buy a package of sawzall blades and go to town on it...
Another quality post.
Real Trucks Rattle
Two broken sawsall blades $10
Busted knuckle, ouch
worn out sawsall, blah blah
Having it done for $5, priceless.
54 3100 with 235
Plumbers cut cast iron pipe with a few different tools, cut off saws,A chain cutter you wrap around the pipe and snap it, sometimes a Porta Band. I've used plently of gas powered cutoff saws, they slice through 1 inch hardened rebar in seconds,takes a minute or so to cut a 4 inch schedule 80 steel pipe.
I believe Fenders is talking about a cast iron sheet not pipe? Use a cut off saw,it'll take a bit of time.Cutting 4 foot through 5/8 material will take a long while with a Sawzall and yes a few blades.
If it's 5/8 pipe,an unusual size, I could buzz through it with a hacksaw in 5 minutes.
Bottom line and several 10 inch cut off sawblades using a power cut off saw ... I took it down town and had a fellow cut it with a plasma cutter ... one of the blades (the last one) almost took the family jewels with it when it exploded ...
family jewels, priceless...
54 3100 with 235
Truckedup ... just for the record, I'm journeyman plumber/gasfitter ... it wasn't pipe ... it was plate ... part of a catch basin ... just a little to big for the existing hole. Thanks for the help tho' ...
I would have used a hand file and worked it down to size for free. grin
Real Trucks Rattle
