2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | I have to cut about a 4ft run of approx 5/8" cast iron ... need some suggestions on the best way ... I have zip wheels (big and small), actylene, again large and small, recip saws etc. Any and all suggestions would be really appreciated. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Acetyline is definitely out- - - -all it will do is melt a big, sloppy groove. The oxygen jet doesn't cut cast at all. I'd suggest getting a gas-engined cutoff tool, the thing that looks like a chainsaw, but uses a big abrasive wheel. With that distance and thickness to cut, you'll go through several wheels, but you'll get a clean, relatively narrow groove. If it's any of my business, just what are you trying to cut? :confused: :confused: :confused: Jerry
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Take it to a plumbing supply place that can cut cast iron pipe. The same machine should be able to cut it for you and they shouldn't charge much. I went to one to have some big pipe cut before.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I'm too cheap to pay someone to do it for me... go buy a package of sawzall blades and go to town on it...
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Two broken sawsall blades $10 Busted knuckle, ouch worn out sawsall, blah blah Having it done for $5, priceless.
| | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Plumbers cut cast iron pipe with a few different tools, cut off saws,A chain cutter you wrap around the pipe and snap it, sometimes a Porta Band. I've used plently of gas powered cutoff saws, they slice through 1 inch hardened rebar in seconds,takes a minute or so to cut a 4 inch schedule 80 steel pipe. I believe Fenders is talking about a cast iron sheet not pipe? Use a cut off saw,it'll take a bit of time.Cutting 4 foot through 5/8 material will take a long while with a Sawzall and yes a few blades. If it's 5/8 pipe,an unusual size, I could buzz through it with a hacksaw in 5 minutes. | | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | Bottom line and several 10 inch cut off sawblades using a power cut off saw ... I took it down town and had a fellow cut it with a plasma cutter ... one of the blades (the last one) almost took the family jewels with it when it exploded ... | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | family jewels, priceless...
| | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | Truckedup ... just for the record, I'm journeyman plumber/gasfitter ... it wasn't pipe ... it was plate ... part of a catch basin ... just a little to big for the existing hole. Thanks for the help tho' ... | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I would have used a hand file and worked it down to size for free.
