1 members (Hotrod Lincoln),
129
Mod | | | Forums66 Topics128,275 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | I've read that the Advance Design truck cabs were widened 8" from the previous generation. While this may be fine for the smaller pickups, looking at the front of my '53 6400, given the height, it seems out of proportion. I think they should have added another 8" or so in width. Using the magic of computer photo manipulation, I did just that to my truck to see what it would look like. You can see some pictures here (I hope that link works). Any opinions? Am I whacko to even consider doing something like this for real?? It'd be tons of work. I originally figured I'd fix up this truck as is (fairly stock), but I just can't seem to leave well enough alone, and I keep coming up with nutso ideas on how to modify the thing. :rolleyes:
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | A wide cab Chevrolet looks neat.You could buy a Heavy Duty GMC, back then, with a wider cab. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Whacko, nutso, maybe, unless you're one heckuva body man! Sounds kinda like you and Chip Foose should get together. Maybe taking about 2 1/2 inches outta the top would bring it back into proportion (for you). Personally, being a big bolt owner myself, I think they are dead-on right from the factory. Big Bolts are something special, save the mods for the smaller trucks.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | I think it looks awesome! | | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Looks good to me. I met a Danbury, CT man who widened his fenders 3" by inserting a section of another fender. This was done to accomodate a '71 4wd frame under his '48 canopy express. Looked good.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | GREAT JOB wish i was more of a computer person. is there a way to manipulate tire and wheel combos on the computer? i have a didgital camera. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2003 Posts: 37 New Guy | | New Guy Joined: Aug 2003 Posts: 37 | Tom at Tommy's Trailers has already done that. He widened his '51 GMC COE to make it work better on a late model chassis. I sounds like a lot of work. [img] http://www.tommystrailers.com/Bertha_4.jpg[/img] | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | My 46 cab is the same size, but I widened my fenders 8 inches. Have a look here and if you want to see more pics of the work in progress go to my photo album. http://pg.photos.yahoo.com/ph/sublime589/album?.dir=d9d2 | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | I had thought of chopping the top a little, but my head comes awfully close to the roof as it is. With that stiff suspension, traveling down a bumpy road, my head might end up like Herman Munster's. I know Foose did that 52 GMC Overhaulin' project, but i'd like to see what he could/would do with a big bolt. I had also thought of just widening the fenders so I could fit in a wider front axle. I think just widening the front track (and maybe rear) would be an improvement, in both appearance and handling. It almost seems like there is enough room in the fenders as it is to widen the axle 6" or so with no tire clearance problems. Ron, it should be possible to try out different wheel/tire combos on the computer. I've thought of trying that myself, but I've never gotten around to it. I'm no expert at this, and the program I have is an obsolete Adobe program that came free with one of my peripherals. I've run across something easier, though, but I haven't tried it yet, either. Go to 1010tires.com and try their "Custom Car Wizard". You can upload a picture of your vehicle into their program and try out any of the wheels they sell. I probably won't end up doing any significant body mods on my truck. I would like to try to shoehorn a new Duramax diesel into the engine compartment though.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Yep, you're nuts.
I'm planning to drop a big bolt cab and fenders on a P30 frame. The P30 track width is about 8 inches too wide, and I haven't decided if the answer is to narrow the track or widen the fenders.
I'm also thinking I need an extended cab, but that's making it longer, not wider, so I'm not nuts like you.
Tommy's truck looks like he used a Suburban roof, and maybe second window. Does anyone know the details of his modifications?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Does anyone know the details of his modifications? I know he widened it 22" and it looks good up close. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | thanks xram 53 i went to the site but have don't time now to play with it, getting ready to got to work. also need to take a side shot of the truck. snowing now not the best time. thanks again. ron
| | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | Tabasco:
That's a crazy looking COE - I like it.
are there other pictures/info of it on the web?
-W | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | See Tommy's COE here on his site. He's also got a Chevy COE for sale here.
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Wow! Great COE there! And on an Isuzu chassis, my favorite! Wonder if the COE list knows about this one? I'm gonna tell!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I think Tommy's truck would look alot better if he had somehow used the orig. grille, & bumper, on that truck. As it is now, if you don't look at it good, & not really familiar with these trucks, you don't recognize what it used to be. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | O.K. xram, now you're talkin'! Duramax diesel? AWESOME!!! You could turn this thing into a real work horse. If you can add some width to the front axle enough to fit the tires into the fenders a little tighter it might make the truck look a little wider. Maybe Alcoa makes some aluminum wheels that'll fit, (duals in the rear) it might look like a downsized semi tractor, maybe some chrome stacks.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Chrome stacks and aluminum wheels?? Somebody's been reading my mind. I was playing with my photo program again. I added a picture to my gallery showing some (crudely drawn) exhaust stacks. I was going to start another thread, but I may as well ask here, since it was brought up--exhaust stacks on a big bolt: cool or tacky...(or something else)?
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Cletis, is that the same truck that we saw in Decatur last yr?? and wasn't it for sale,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | We be Old: If you need an image manipulated or restored just go to my site. link below.
delete my account and pictures
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yep Fred, that's the one. It was at the meet in Fort worth in Nov. also.
Spanky, I know what you mean. The first time I saw it I had to stare a bit to figure out what it was. A real mind bender. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The first time I saw that COE, my first thought was, someone ruined a perfectly good COE. Yes, it has been For Sale before, & I'm a firm believer that it's "Radical" looks, are keeping it from selling. Xram53, the '47-'55 GMC 400, 450, & 470 series trucks, had wider wheelbases than the Chevrolets, which called for them to have larger, wider, fenders. | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | xram, I have the 1/2 ton and 3/4 ton pickups drawn on AutoCAD and that how I paly with different ride heights and wheel combo's. Its just a line drawing, but it works pretty well. I like the stock wheels and hubcaps, but its easy to draw any of the custom wheels and place them in there. All I need is a picture of the wheels to look at. Ralph | | |
