| | | Forums66 Topics128,095 Posts1,056,077 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | A Dual Wheel Bench Grinder like this 4343495473 , where I can add a motor to it?? This seemed to be the only one I could find on eBay, I just wanted to see if I had more choices, if not I guess I will bid on it. Does anyone know of a website, or someplace I could get one? Thanks, - Shane
- Shane (ChevyToughRebel) 2 Trucks; -1955 3/4 Ton Chevy -1979 3/4 Ton Custom Deluxe 20 4x4 1955 Second Series 3600 GED = Git Er Done
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Originally posted by ChevyToughRebel: A Dual Wheel Bench Grinder like this 4343495473 , where I can add a motor to it?? This seemed to be the only one I could find on eBay, I just wanted to see if I had more choices, if not I guess I will bid on it. Does anyone know of a website, or someplace I could get one? Thanks,
- ShaneJust out of curiosity, why would you want this typw instead of a direct drive unit? These are always underpowered and they stop when any amount of pressure is exerted on the wheel. I have one at my inlaws, it uses an old wash machine motor and it's only good for small stuff. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I dont know where else you would find one,but they are definitly a nice piece of equip.to have.I have one that is much bigger and runs at a slow speed,very nice for sharpening lawn mower blades etc.You can sharpen blades without burning them up. | | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | That would be nice with a 3HP motor and a variable speed drive. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Do not get a cheap dual wheel grinder. I have one and many, many occasions wanted to throw it over the hill. Dual wheels are fine if you get the right Hp power. I get so mad I usually use my 4" grinder.
popcorn The Truth is Out There (Working on these ol trucks you need a GOOD grinder like haveing a BIG heavy duty vice) | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hey Shane, I use a bunch of those type of grinder bases with my own motors. They work well for the polishing and sanding. I purchased mine fron Brownell's gun supply catalog which is available on-line. I will caution that you can buy a Harbor Freight 6" or 8" grinder for a lot less money. I hate to buy foreign junk, but there are no american made grinders in my price range so I just look at them as disposable. I use Baldor 1 hp minimum motors on mine. Ralph | | | | | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Well, I like these better than the direct drive, they seem to have more room to work with. My step dad has one, and it works great, it has never slowed down to o stop either. I wont be bidding on it though, I am out of money - Shane
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Shane...
Buy that one... 7 day auction...1 day left...no bids....
Snipe it. Shipping might be a few bucks...you just might get it for $1.99....tell em by the cheapest method possible...mule train if you have to.....probably cost you $30 for shipping...
but that cast iron looks pretty heavy in the picture..... | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Go to your local tractor supply house, get a 3/4" shaft, a couple mounted bearings & a pulley, & another pulley for the motor. All I have ever seen were homemade, usually mounted to the workbench corner. Brian | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | That one's not even worth the minimum bid! I build my own with pillow block bearings and shaft material and pulleys purchased from Grainger. Old washing machine motors, etc., come in handy as power units. I keep several sets of buffing wheels mounted up for polishing gun parts prior to bluing. Each wheel has a different grit of polishing compound worked into the wheel. Jerry
| | | | | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Well, as much as I would like to, I dont have money to spend on this unit, shipping was around $27. I have been buying buildable model cars and trucks, like these: 64 Fleetside & 68 El Camino SS & 63 Impala SS - Shane
| | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Just keep a look out at the local garage sales and what not. I am sure if you are not in a hurry you will be able to find one for about $5.00.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
