3 members (Rexville48, 59 fleet, Otto Skorzeny), 121 guests, and 2 robots.
Topics128,070
Posts1,055,896
Members48,428
#168442 12/16/2004 6:58 AM
A Dual Wheel Bench Grinder like this 4343495473 , where I can add a motor to it?? This seemed to be the only one I could find on eBay, I just wanted to see if I had more choices, if not I guess I will bid on it. Does anyone know of a website, or someplace I could get one? Thanks,
- Shane
- Shane (ChevyToughRebel)
2 Trucks;
-1955 3/4 Ton Chevy
-1979 3/4 Ton Custom Deluxe 20 4x4
1955 Second Series 3600
GED = Git Er Done
#168443 12/16/2004 7:50 AM
Quote
- Shane
Just out of curiosity, why would you want this typw instead of a direct drive unit? These are always underpowered and they stop when any amount of pressure is exerted on the wheel. I have one at my inlaws, it uses an old wash machine motor and it's only good for small stuff.
#168444 12/16/2004 11:58 AM
I dont know where else you would find one,but they are definitly a nice piece of equip.to have.I have one that is much bigger and runs at a slow speed,very nice for sharpening lawn mower blades etc.You can sharpen blades without burning them up.
#168445 12/16/2004 4:44 PM
That would be nice with a 3HP motor and a variable speed drive.
#168446 12/16/2004 6:54 PM
Do not get a cheap dual wheel grinder. I have one and many, many occasions wanted to throw it over the hill. Dual wheels are fine if you get the right Hp power. I get so mad I usually use my 4" grinder.
popcorn The Truth is Out There (Working on these ol trucks you need a GOOD grinder like haveing a BIG heavy duty vice)
#168447 12/16/2004 11:28 PM
Hey Shane,
I use a bunch of those type of grinder bases with my own motors. They work well for the polishing and sanding. I purchased mine fron Brownell's gun supply catalog which is available on-line. I will caution that you can buy a Harbor Freight 6" or 8" grinder for a lot less money. I hate to buy foreign junk, but there are no american made grinders in my price range so I just look at them as disposable. I use Baldor 1 hp minimum motors on mine.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
#168448 12/16/2004 11:36 PM
Well, I like these better than the direct drive, they seem to have more room to work with. My step dad has one, and it works great, it has never slowed down to o stop either. I wont be bidding on it though, I am out of money frown
- Shane
2 Trucks;
-1955 3/4 Ton Chevy
GED = Git Er Done
#168449 12/17/2004 12:14 AM
Shane...
Buy that one... 7 day auction...1 day left...no bids....
Snipe it. Shipping might be a few bucks...you just might get it for $1.99....tell em by the cheapest method possible...mule train if you have to.....probably cost you $30 for shipping...
but that cast iron looks pretty heavy in the picture.....
#168450 12/17/2004 12:19 AM
Go to your local tractor supply house, get a 3/4" shaft, a couple mounted bearings & a pulley, & another pulley for the motor. All I have ever seen were homemade, usually mounted to the workbench corner. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#168451 12/17/2004 2:20 AM
That one's not even worth the minimum bid! I build my own with pillow block bearings and shaft material and pulleys purchased from Grainger. Old washing machine motors, etc., come in handy as power units. I keep several sets of buffing wheels mounted up for polishing gun parts prior to bluing. Each wheel has a different grit of polishing compound worked into the wheel.
#168452 12/17/2004 6:19 AM
Well, as much as I would like to, I dont have money to spend on this unit, shipping was around $27. I have been buying buildable model cars and trucks, like these: 64 Fleetside & 68 El Camino SS & 63 Impala SS
- Shane
2 Trucks;
-1955 3/4 Ton Chevy
GED = Git Er Done
#168453 12/17/2004 6:56 PM
Just keep a look out at the local garage sales and what not. I am sure if you are not in a hurry you will be able to find one for about $5.00.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
