| | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | What should I put in the steering box? It smells like 90wt but the book says to use steering box oil, which is.... | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I heard most of these old steering boxes leak. Mine leaked so I emptied it and packed it full of grease aswell. | | | | | Joined: Aug 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 51 | SAE 90 "Multi-Purpose" is what I use...
1965 C-10 Stepside
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | My leaker uses STP. Top it off every few months.
40 Chevy 1/2 ton
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Its much higher than 90. I use Penrite Oil and its found at www.classicautolubes.com . Its called steering box lube and cost about $12. That includes shipping. You only need 1 bottle. Has a pop up tube so you can squeeze it in. Cecil.......... | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I use penrite steering box lube too . I think it is more like 600 wt . helps to warm it in the sun for a few hrs before trying to pour it  . Works very well , a good product. | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | While STP is readily available, Penrite is the way to fly (according to boards as well). | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you use grease and live north of the Mason-Dixon line, use a moly grease instead of lithium, it is softer at cold temps.
Fred 52 3600 69 C-10
