0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#168274 11/18/2004 12:53 AM
What should I put in the steering box? It smells like 90wt but the book says to use steering box oil, which is....
#168275 11/18/2004 1:58 AM
I heard most of these old steering boxes leak. Mine leaked so I emptied it and packed it full of grease aswell.
#168276 11/18/2004 3:24 AM
SAE 90 "Multi-Purpose" is what I use...
1965 C-10 Stepside
#168277 11/18/2004 4:01 AM
My leaker uses STP. Top it off every few months.
40 Chevy 1/2 ton
#168278 11/18/2004 6:33 AM
Its much higher than 90. I use Penrite Oil and
its found at www.classicautolubes.com . Its
called steering box lube and cost about $12.
That includes shipping. You only need 1 bottle. Has a pop up tube so you can squeeze it
in. Cecil..........
#168279 11/18/2004 6:53 AM
I use penrite steering box lube too . I think it is more like 600 wt . helps to warm it in the sun for a few hrs before trying to pour it grin .
Works very well , a good product.
#168280 11/18/2004 5:23 PM
While STP is readily available, Penrite is the way to fly (according to boards as well).
#168281 11/18/2004 6:42 PM
If you use grease and live north of the Mason-Dixon line, use a moly grease instead of lithium, it is softer at cold temps.
Fred
52 3600
69 C-10
