2 members (R&S 51 GMC, Bill Hanlon), 90 guests, and 3 robots.
Topics128,125
Posts1,056,338
Members48,440
#168026 04/25/2005 7:23 PM
Did Chevy use a support brace on the roof for all AD years? Mine has none, and there are no mounting holes or signs that someone cut it off (no signs of welds where it would have attached). I'm not sure which year my cab was built, but I think it is 51,52,or 53.
'53 chevy 3/4 ton
#168027 04/25/2005 8:46 PM
Anonymous
Unregistered
Anonymous
Unregistered
I am not clear on what you mean in terms of a support brace? Can you clarify? Are you talking about the headliner bracing or a structural bracing?
#168028 04/25/2005 8:55 PM
I'm not sure........ my cab has nothing at all across the inner roof panel. I've seen some other AD cabs which have a cross member of some sort. Perhaps this is just something to attach headliner to?? I just need to know what needs to be there in order to attach the headliner board and/or support the roof. thanks
'53 chevy 3/4 ton
#168029 04/25/2005 9:07 PM
Anonymous
Unregistered
Anonymous
Unregistered
There is a headliner bow. It is not a structural member for the roof. It is a type of "S" channel which unfortunately is not reproduced to my knowledge but they do make one piece headliner pans which you can paint or upholster to match your interior. Hope this helps. If you must have one then I would look either in the swap meet here or on another old truck. Should be the same for all year AD trucks.
#168030 04/25/2005 9:13 PM
ok, so if I decide to use a one-piece headliner kit I can just install without having to find or make any sort of cross piece. That sounds great.
thanks much!!!
'53 chevy 3/4 ton
#168031 04/25/2005 9:18 PM
There are two kinds of headliner bows for the AD series. There were fastened differently but did the same job.
1951 1 Ton Completed
