| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | Did Chevy use a support brace on the roof for all AD years? Mine has none, and there are no mounting holes or signs that someone cut it off (no signs of welds where it would have attached). I'm not sure which year my cab was built, but I think it is 51,52,or 53.
'53 chevy 3/4 ton
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I am not clear on what you mean in terms of a support brace? Can you clarify? Are you talking about the headliner bracing or a structural bracing? | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | I'm not sure........ my cab has nothing at all across the inner roof panel. I've seen some other AD cabs which have a cross member of some sort. Perhaps this is just something to attach headliner to?? I just need to know what needs to be there in order to attach the headliner board and/or support the roof. thanks
'53 chevy 3/4 ton
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | There is a headliner bow. It is not a structural member for the roof. It is a type of "S" channel which unfortunately is not reproduced to my knowledge but they do make one piece headliner pans which you can paint or upholster to match your interior. Hope this helps. If you must have one then I would look either in the swap meet here or on another old truck. Should be the same for all year AD trucks. | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | ok, so if I decide to use a one-piece headliner kit I can just install without having to find or make any sort of cross piece. That sounds great.
thanks much!!!
'53 chevy 3/4 ton
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There are two kinds of headliner bows for the AD series. There were fastened differently but did the same job. | | |
