Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, Shof, 55shaker), 163 guests, and 2 robots.
Topics128,281
Posts1,058,488
Members48,490
#167443 09/15/2004 11:21 PM
Junior Member
Junior Member
I've looked just about everywhere I can on the site and can't find quite what I'm looking for -- please forgive me if it's been asked before.
I have a 65 with (I think) a 250ci 6 cyl and a Powerglide. I've about figured out the engine situation and want to put in a 350. It seems like that ought to bolt in pretty easily. I would like to pair the 350 with a TH 350 or 400. THE QUESTION IS how easily will one of these trans bolt in where the Powerglide was? I'm not afraid of welding but would like things to be as simple as possible ('cause I'm lazy).
I have more of a racing background so the old iron is an entirely new deal. Thanks for the advice, also appreciate any "Lookout!" advice anyone has on the engine/trans swap.
Dave Cox
#167444 09/15/2004 11:51 PM
The bellhousing and torque converter is pretty much a bolt-in swap. You'll probably have to fabricate a driveshaft, and possibly a rear crossmember. Given the choice, I'd pick a TH 350, it's lighter weight than the 400. If you want overdrive, try an early-model TH700, before they went to computer control on the converter clutch lockup. The early ones had a vacuum switch and a single wire going to a pressure switch, and the clutch locked in by governor pressure. Later models used the vehicle's engine control computer and the Vehicle Speed Sensor in the speedometer head to control TCC lockup. Lots of wiring headaches with the late-model oners!
#167445 09/16/2004 3:41 AM
Wouldn't a short tail shaft Turbo 350 bolt in right where the Powerglide was. I think they are about the same length. I think the 350 would work better with a 6 than a 400 would.
#167446 09/16/2004 3:48 AM
I think dimensionally it measures the same. I think you will need a new yoke for your driveshaft.I think the glide and the t350 have different tailshaft splines. It's been a long time, I can't remember all of the little differences,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
