7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#167399 04/22/2005 11:42 AM
can find no numbers on the 1940 suburban I think?- I looked on right side of cowl on and under dash on seat frame and left-hinge piller post, no luck
Would the vin/ID be stamped on the frame or anywhere else on suburban? thanks Bill
I had the same problem with a 37 Chevy sedan.Stamped the VIN no.on the frame.
No vins anywhere else....
The only place the vin was installed was on the plate, under the hood on the cab, passenger side.
Stand on the passenger side of your truck, look at the back end of the hood, lower. If you open the hood, either the plate, or 4 holes should be there....
Some states used the engine serial number as the vin.
Fred
52 3600
69 C-10
46-- There is a place where the vin tag may have been on pass firewall.
Fred-- P.O. is trying to find an old reg or some paper work with vin on it. In Maine I will be able to licence. it with the motor number and bill of sale. The vin would tell me what it realy is I think new it was an 8 passanger suburban carryall? It has the wrong beanch seat in front no rear seats but all 6 side windows have handles to crank them up and down.Wood back floor barn rear doors with small oval windows a 4 speed trans. There must be different models I see photos of 40s with head lights on fender and with them mounted to side off radiator support/grill support like the one I have?
thank you all for your help I am sure I will need more addvice as I work along on this. Bill
