8 members (dt235sd, Lonnie, Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 2 invisible),
193
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | can find no numbers on the 1940 suburban I think?- I looked on right side of cowl on and under dash on seat frame and left-hinge piller post, no luck Would the vin/ID be stamped on the frame or anywhere else on suburban? thanks Bill | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I had the same problem with a 37 Chevy sedan.Stamped the VIN no.on the frame. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | No vins anywhere else....
The only place the vin was installed was on the plate, under the hood on the cab, passenger side.
Stand on the passenger side of your truck, look at the back end of the hood, lower. If you open the hood, either the plate, or 4 holes should be there.... | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Some states used the engine serial number as the vin.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | 46-- There is a place where the vin tag may have been on pass firewall. Fred-- P.O. is trying to find an old reg or some paper work with vin on it. In Maine I will be able to licence. it with the motor number and bill of sale. The vin would tell me what it realy is I think new it was an 8 passanger suburban carryall? It has the wrong beanch seat in front no rear seats but all 6 side windows have handles to crank them up and down.Wood back floor barn rear doors with small oval windows a 4 speed trans. There must be different models I see photos of 40s with head lights on fender and with them mounted to side off radiator support/grill support like the one I have? thank you all for your help I am sure I will need more addvice as I work along on this. Bill | | |
