0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 22 New Guy | | New Guy Joined: Mar 2005 Posts: 22 | I want to at a later date (when money is avalable) to replace my brakes with power disk up front. I dont like running with the stock one for now. I would like to change over to a double chamber for safety reasons. Which one workes on the 66 with the least trouble of hooking up.
Doug
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Welcome! If you are keeping the drums a 68 C10 will work. Split the lines down by the tee down by the starter. Brian | | | | | Joined: Mar 2005 Posts: 22 New Guy | | New Guy Joined: Mar 2005 Posts: 22 | Thanks Brian, I figured there would be a simple swap for this.
Doug
| | | | | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | I don't know about the master cyl, but if you want discs up front without spending a ton of cash on one of the conversion kits out there, find a '73-'85 chevy half ton and swap the entire crossmember; it bolts right in.
Check out my website; I chronicled the swap I did on my '64. | | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | You can use the dual master cyl off of a full size chevy car and it will bolt to the two hole that are across from each other and you put the other two bolts back in to holed everything inside together, that how i got a dual master cyl on my 63 c10 that had one cyl for all four brakes and you will needed a proportioning valve, the one I used was from a 76 caprice with front disk brakes.
super250six | | |
