8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#167333 03/30/2005 3:25 AM
I want to at a later date (when money is avalable) to replace my brakes with power disk up front. I dont like running with the stock one for now. I would like to change over to a double chamber for safety reasons. Which one workes on the 66 with the least trouble of hooking up.
Doug
#167334 03/30/2005 4:32 AM
Welcome! If you are keeping the drums a 68 C10 will work. Split the lines down by the tee down by the starter. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#167335 03/30/2005 9:45 PM
Thanks Brian, I figured there would be a simple swap for this.
Doug
#167336 03/30/2005 11:23 PM
I don't know about the master cyl, but if you want discs up front without spending a ton of cash on one of the conversion kits out there, find a '73-'85 chevy half ton and swap the entire crossmember; it bolts right in.
Check out my website; I chronicled the swap I did on my '64.
Mike from Alabama
My truck on Stovebolt
My website
Why do we drive on a parkway, and park on a driveway?
#167337 03/31/2005 2:56 AM
You can use the dual master cyl off of a full size chevy car and it will bolt to the two hole that are across from each other and you put the other two bolts back in to holed everything inside together, that how i got a dual master cyl on my 63 c10 that had one cyl for all four brakes and you will needed a proportioning valve, the one I used was from a 76 caprice with front disk brakes.
super250six
