3 members (BC59, dt235sd, Wooley), 124 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
#166978 11/06/2004 1:50 PM
1 Offline
I have a 51 5-window chevy 1/2 ton, I want to put a ford 9" inplace under the existing springs. Is there a kit available for mounting the spriungs to the new axle housing including spring perches. Also I may be interested in going to a monoleaf with the same ford 9"
most of the truck parts catalog have them. brotherstrucks.com , chevy duty.com and you can go lowering springs or mono. i got mine from fatfendered.com. i gave you the online address it would be quicker to look there rather than order their catalog.. hope this answers your question. ron p. s. get a copy of classic trucks magazine it will be a big help
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I got my axle mounting kit from ccp products,about 100,00. I used a gm 10 bolt out of a mid eighties full size blazer six lugs, almost exact width on my 51 3100. pld navy51....
1 Offline
thankyou for the info, is the magazine custom truicks, or custom classic trucks
#166982 11/12/2004 10:33 PM
Junior Member
Junior Member
The magazine is called Classic Trucks. Here is their web site. http://www.classictrucksweb.com/
#166983 11/12/2004 11:12 PM
Just cut the ole stuff off with a cuttin torch and weld on new perches--get em at a trailer shop or Ive seeen metal square tube used--save the $100.
Buzz'n Half Dozen
#166984 11/12/2004 11:22 PM
If you want to do a good job for little bucks,Buy two spring perches or saddles from any speed shop, Jegs or Summit online or A Mopar dealer can get them for from the Mopar performance catalog ,about 15 bucks.Your local spring shop can fix you up with U-bolts for another25- 35 bucks.S10 lower plate works out well, just enlongate the U bolt holes slightly, and it even has a shock mount.
Don't forget to mock up the rear axle and fenders,moving the axle back an inch or so gets the tire centered in the fender opening.Just drill a new center bolt hole in the spring perch.
You also have to be sure your driveline geometry is correct. The pinion shaft must be parallel to the transmission shaft within a few degrees. Read the article at http://www.classictruckshop.com/driveline.asp
Tuftruck,
Take a look at MacGyvers website, they have a kit or parts for the conversion you want to do. They are in Alberta, so Canadian $$ and no customs or shipping hassles.
http://www.macgyvers.com
I bought my suspension stuff from them. Good people to deal with.
-Floyd
