| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | I have a 51 5-window chevy 1/2 ton, I want to put a ford 9" inplace under the existing springs. Is there a kit available for mounting the spriungs to the new axle housing including spring perches. Also I may be interested in going to a monoleaf with the same ford 9" | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | most of the truck parts catalog have them. brotherstrucks.com , chevy duty.com and you can go lowering springs or mono. i got mine from fatfendered.com. i gave you the online address it would be quicker to look there rather than order their catalog.. hope this answers your question. ron p. s. get a copy of classic trucks magazine it will be a big help
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I got my axle mounting kit from ccp products,about 100,00. I used a gm 10 bolt out of a mid eighties full size blazer six lugs, almost exact width on my 51 3100. pld navy51.... | | | | | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | thankyou for the info, is the magazine custom truicks, or custom classic trucks | | | | | Joined: Jul 2003 Posts: 26 Junior Member | | Junior Member Joined: Jul 2003 Posts: 26 | The magazine is called Classic Trucks. Here is their web site. http://www.classictrucksweb.com/ | | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Just cut the ole stuff off with a cuttin torch and weld on new perches--get em at a trailer shop or Ive seeen metal square tube used--save the $100.
Buzz'n Half Dozen
| | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | If you want to do a good job for little bucks,Buy two spring perches or saddles from any speed shop, Jegs or Summit online or A Mopar dealer can get them for from the Mopar performance catalog ,about 15 bucks.Your local spring shop can fix you up with U-bolts for another25- 35 bucks.S10 lower plate works out well, just enlongate the U bolt holes slightly, and it even has a shock mount. Don't forget to mock up the rear axle and fenders,moving the axle back an inch or so gets the tire centered in the fender opening.Just drill a new center bolt hole in the spring perch. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You also have to be sure your driveline geometry is correct. The pinion shaft must be parallel to the transmission shaft within a few degrees. Read the article at http://www.classictruckshop.com/driveline.asp | | | | | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | Tuftruck, Take a look at MacGyvers website, they have a kit or parts for the conversion you want to do. They are in Alberta, so Canadian $$ and no customs or shipping hassles. http://www.macgyvers.com I bought my suspension stuff from them. Good people to deal with. -Floyd | | |
