| | | Forums66 Topics128,274 Posts1,058,435 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Recived my Dash replacment ...Anyone ever done this...any helpfull hints?
HURRY UP AND WAIT 55 235 3/4
| | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | A complete dash replacement? I had to do mine on my 53 3100 and it involved drilling out what seemed like an endless amount of spotwelds. | | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | This is one post I'll be watching! I need to replace mine this summer. I've got the welder, now I just need to but the C25 and run a few practice welds.
Honestly, if you take your time measure three times before you cut and are comfortable with your welder - should be to big a deal.
Good luck, and post some pix (before and after). | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | No Not complete dash, just were the radio goes. I will do a before ..during..and after..
| | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | i am going to start it today...I will be taking pics to post..maybe posted on monday..or tuesday..Unless I really mess it up.M/G
| | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Got stalled on the cutting part. Bought a Dremmel from Harbour Fr., used it 30 min..clutch went out on it...brought it back..got another..used it fir 10 min...clutch went out on it...threw it across the street..
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Hey Here's a tip take out your inner fire wall cover so it doesn't catch on fire. Guess you found that out. If you want to cut metal use a die grinder and a cut off wheel. Works great for grinding welds too. | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I was just out grinding some high spots on the weld around the face plate..that s... is tuff as hell to grind down. Its coming along good though. Its gonna be great when i can put all my knobs on and Finally paint the interior...wont be long now.Except i have to buy a new inner fire wall cover...ha ha ha
| | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I should have some pics by Monday...it came out pretty good, just got to put some bondo around the edges.
| | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Hey Mike, Where're the pix? I'm looking for some encouragement  | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | You're killin' me Mike! I need to see some pictures. | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I was on Vacation...Finally, I am going to Grind the dash panel today, then run some bondo to smooth it out a bit, I promise,,pics are on the way,,,M/G
