Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Woodcmiami, rfs56trk, Cosmo, cmayna), 37 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#166364 07/06/2007 2:30 AM
OK you gooroos of the stovebolts! Where can I find new or replaceable door glass glides(3 rollers the door glass raises up and down with)I think that's what they are called. I found them for '55 and newer but will they work on my '48? I know I will have to drill them out but there has to be another way other than buying new regulators , mine r fine just no rubber on the wheels.
Thanx! Mike
#166365 07/06/2007 4:24 AM
Mike I'm going to address this to a '50, but I think the '48 on up were the same.
There isn't any roller on the regulator. the window guides ride on the posts that are rivited to the arms and what you may think is rubber is in reality leather washers on each side of the guide. there are two different sized washers used on each post and they are lubed with lithium grease.
Take a look here, this should make it pretty clear: http://rides.webshots.com/photo/2924571610098611668SAUVbW
http://rides.webshots.com/photo/2566710950098611668bcnMYR
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166366 07/06/2007 11:57 AM
Denny, You are "THE MAN"!!!!!! It looks as though the "glides" are the steel rivets and the leather washers work as a oiler for the track and somewhat of a anti-rattler, but thats exactly what I need....WHERE can I purchase 12 of those leather washers or can I?
Thanx for the Reply and the help!
Mike
#166367 07/06/2007 1:55 PM
The simple answer is you can't Mike. This is where the restoration part of the game comes in to play. If you just want to fix it, there are several vendors that sell replacement "nylon" rollers on Aluminum studs. I suppose these would work ok. I chose to make my own "Steel" studs which are exact copies of the original ones. I spun them up on the lathe. They are riveted to the regulator the same as the originals. The leather I got from Tandy Leather, as you can see from the pictures I stamped out the centers with a stamp that I made in the lathe and stacked them on a mandrel then turned the OD to match the original set if leathers. And yes I believe they act exactly as the description in your reply, that is as a wick for the grease and anti-rattle.
And no I have no planes to start selling them, I’m rebuilding two sets and made some extras to rebuild a friends windows with. I had given some thought to having a run of them made up out of SS on a CNC but my access to a CNC dried up last year. The leathers I could have punched out at Chicago Rawhide if the run was big enough. That’s the problem, to make things like this practical from a financial stand point I would probably have to run a minimum of 10k and I don’t think I would live long enough to sell 10,000 sets.
After installation of the rebuilt regulators, window run channels, anti-rattle strip (aka cats whiskers) and rubber, the windows feel just as they did when new. They operate very smooth and have no rattles when up or down. The only tell tale sign that it is not new is about 10° play at the crank due to a little wear in the gearing.
If ya got any more questions about how I made the parts don’t hesitate to ask.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166368 07/06/2007 8:44 PM
Denny, would you mind posting the diameter of the washers,and the thickness? I just redid the drivers door, and the original leather washers were so shot I couldn't get a measurment. I finally made washers out of nylon and used them. Also the stud on the window regulator in my 52 was just swaged on. I heated the stud and just center punched it out. After installing the washers I just swaged it back on to the arm, Jimmie.
#166369 07/06/2007 11:48 PM
You guys are better than me and have more boy toys(tools of the trade)than me so I guess I'll just buy them.... I wonder if rubber flat washers will work ? like thin smaller garden hose washers? Might have ti try that.
Thanx for the feedback!!!!!!!!!!!!!Mike
#166370 07/07/2007 2:34 AM
Be careful you don’t want to bend the regulator arms or it will bind on you. I drilled out most of the hollow rivet head before I tapped them out. To set the rivet head on the new studs I used a ball bearing that was a little larger than the inner diameter and gave it a little shot with the hydraulic bench press.
I wouldn’t use rubber for the washers because its not going to hold any lubricant and it could roll up and bind up the track. I was originally going to use Delrin but after a through autopsy I discovered that the "rolleres really werent rollers at all and that they were really leather. Wash your old ones real good and then look at them with an eye loupe and you will be able to see the grain.
The size of the leather washers is: http://rides.webshots.com/photo/2910723670098611668DIUeda
You probably won’t be able to make out the dimensions but they are .100" to .125” thick and the inner one is .375” x .875”, the outer one is .440” x .950”
A leather belt may supply you with the material that you need. If you don't have an old one you can probably find a blank at a craft store.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166371 07/07/2007 2:57 AM
try a shoe repair shop for the leather. I've followed these post with interest as I know my time will come. Its just that you guys are light years ahead of me!
#166372 07/07/2007 3:14 AM
Denny, thanks, and to all who had ideas for the leather. I used to do leather tooling for fun, and still have the tools, and scraps that I can use. Now all I have to do is find my calipers and something to make a punch out of. Jimmie.
#166373 07/07/2007 3:23 PM
Ah-Ha!!! I see why they closed the tread now, wish the moderator would say, "moved topic" to the proper forum.
Gasket punches are available at all the swap meets that I have been to from the vendors that follow the meets around all summer, usually in a large variety of sizes and cheap. If you have access to a lathe punches are easy enough to turn. If you can find plane old steel tubing the right size, conduct, black pipe, galvanized, etc., you can sharpen the end with a file or Dremel, punches at your leather craft supplier, lots of possibilities.
Leather scraps at the shoe maker Fred?? There tain’t no shoe makers left round here any more are there? Must be another one of those foreign phenomenon’s ya all still have up thar in Cana’deia! But seriously that’s a good suggestion, never thought of that source.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166374 07/08/2007 12:58 AM
I think we're all straightened out on that Mike. I felt a little picked on by Charlie when he first took over as a moderator but now I understand. The moderators do have a rotten job, something like the umpire at a ball game. Their decisions arn't always popular with everyone. I sure wouldn't want the job.
I'm starting on another door this weekend. Probably gonna pull the regulator and rest of the guts out tonight. If you do them like I did, I think your gonna be more than pleased with the results.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166375 07/08/2007 1:06 AM
Z
Z Offline
Quote
Originally posted by bowtiesr4me:
THE MAIN REASON i PUT THIS IN THIS TOPIC BECAUSE HARDLY NOBODY READS THE "DOORS OR INTERIOR" FORUMS.
If people were to post whatever they wanted wherever they wanted what would be the point of having categorized forums. Moderators do what they need to do to keep the site running well. You are more than welcome to start your own site and post wherever you like and use ALL CAPS as much as you want.
1946 Chevy Pickip
#166376 07/08/2007 1:06 AM
Thanx Denny! and to you Achipmunk, I found a "shadetree" leathersmith and said he would try making the washers I need.
Moderators keep up the good work, I wouldn't want to go all those innings with all these folks! Thanx!!!!!
bowties
#166377 07/08/2007 4:47 PM
Come on ZIPPER, lighten up, nobody wants to set any fires here. It can be a little frustrating at times trying to figure out just where to open a discussion where it will be seen. It's very true that the vast majority of the bolters only have time to look at a couple of forums, usually the "General Talk" first and the "Engine & driveline" second by then it's time to go tend to the chores or eat supper.
I'll bet that there are forums here that you an I have never even opened or only brefly scan once a month or so. If this thread had started out in "Doors" I probably would never have read it.
Glad it's working out for you Mike, I think your going to be real happy with the results.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166378 07/09/2007 2:34 AM
Apprentice
Apprentice
Denny,Thanks for your photos of the leather washers.I turned a stack of washers on the lathe and they looked good.My guide pins were good so I soaked the washers in hot water for about 20 minutes and was able to stretch them over the pins.When they dried they shrunk back to the orig. size and I didn't have to make new pins!If someone doesn't have access to a lathe you could punch the i.d. with an empty pistol shell case and you could cut the o.d. with a pair of snips just so it will slide inside the track.Improvise! Chip
#166379 07/09/2007 3:04 AM
Hey Chip I have heard of that too about using a shell but wasn't shure what size. Thanx to everybody for the help on my project!....:^)
#166380 07/09/2007 3:54 AM
Come on Mike turn the other cheek!
Sounds like you got a handle on it Chip. As a matter of fact since there isn't any roller thing goin on there like some believe, for all practicle pourposes you could probably make the leathers square as long as they slid free in the channel. The ID is kind of important cuz ya don't want them fitting to loose and the thickness needs to be pretty close or they will be to tight or to loose in the channel.
Denny Graham
Sandwich, IL
Denny G
Denny G
Sandwich, IL
#166381 07/09/2007 12:47 PM
Your right Denny, Have a great day!
Mike
Moderated by  ndkid275, Phak1
