3 members (Materman, blanch53, 1 invisible), 125 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
8
Junior Member
Junior Member
8 Offline
greetings,
need some help... replaced the two piece windshield glass in my 1950 chevy truck with a mitered one piece set up... very cool, but now the metal piece that once held the rearview mirror is gone... just thinking, is there an interior rearview mirror that mounts to the dashboard, ie. a mirror on a stick of some sort, that lets me see out the back window? i remember seeing such a unit at a car show sometime ago but of course, what car it was escapes me.
the peep mirror hung on the outside of the truck does help, but i find myself looking at where the rearview should be...
thanks for the help, i am ohwell on this one
RT1 Offline
Late 50's early 60's Corvette mounted on the dash...
8
Junior Member
Junior Member
8 Offline
thanks!
Don't know if this will be of any help but the 54 mirror mounts above the windshield.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
8
Junior Member
Junior Member
8 Offline
dave... if you get a chance could you send a pic of the mirror? i will check out harmon's to see the mirror... thank you
paul
Hi Paul....I've added a pic and the info to my "Tips and Tricks" Webshot album. The mount bracket has 5/16 fine female threads. I just found a salvage nite/day mirror with the ball socket....fitted perfectly. Hope this helps.
Dave
8
Junior Member
Junior Member
8 Offline
dave... thanks so much for the pic... i', gonna buy the 1954 mirror and bracket from harmons... looking at the bracket, if it doesn't work on the top of the cab surround, it may work by bolting it down to the dashboard for a custom look... i appreciate the help!
paul
Seems to me like if you put it on the dash,all you'll be able to see is the back wall of the cab...
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
8
Junior Member
Junior Member
8 Offline
dave and speed...
bought the '54 mirror, found a perfect place on the dash and presto custom mirror... with a four inch chop of the cab, it works perfect AND inspires others to ask questions about where i got it smile
Moderated by  ndkid275, Phak1
