3 members (tclederman, EchoBravoSierra, Hanks custodian), 255 guests, and 1 robot.
Topics128,100
Posts1,056,170
Members48,436
#166252 06/11/2007 10:09 PM
Hi everybody, as you can tell from my posts I am working on the interior of my 52. As I was removing the passenger side old windlace, I noticed that about two feet had come loose from the spot welds. I don't see any way to re-spot weld the thin metal of the channel back, so I guess plug welding is the answer (unless somebody has a better way). So I have a twofold question, 1 is plug welding the best answer to my problem, and any suggestions on a mig/tig welder to do the job. I am fairly good at arc welding. And as much as I would like to purcahse a Hobart, Lincoln, or Miller welder I can't afford 3 grand for a tool for my hobby. So 2 any suggestions for a shade tree welder? Any suggestions or observations are welcome, Jimmie.
#166253 06/12/2007 1:06 AM
Don't know if this will do you any good but drilling the channel in a few spots and hitting it with a small rod and lower amperage should do the trick. That's assuming you've got access to a stick welder. If that isn't the case I'd be tempted to use a pop rivet and a heat gun to warm the rubber so you could work it around the head. Mine didn't go into the track and feed around....had to work it in with a blade, inch by brutal inch!!!
I've got an old-time stick welder....sprung for a mig w/gas.....great for occasional light work but I get a whole lot more use out of my stick or oxyacetylene. Kinda hard to justify having that kind of coin tied up in a machine unless you're using it on a regular basis.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#166254 06/12/2007 12:58 PM
pop rivet it back together, then smash the head down for windlace clearence.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#166255 06/13/2007 11:45 AM
Hey guys, thanks for the input. I have an old Craftsman 110 volt stick welder that I bought years ago. It can use rod down to 3/16 so that is probably what I will do. I know this won't help now, but I used petroleum jelly on the windlace, and channel. Then the windlace just slipped right in. Jimmie.
#166256 06/19/2007 7:14 PM
Stick welding might make a mess. I went Wilbur's route and riveted them on. They can be installed after painting that way too. Good luck.
Curt B.
You Tube
Moderated by  ndkid275, Phak1
