| | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hi everybody, as you can tell from my posts I am working on the interior of my 52. As I was removing the passenger side old windlace, I noticed that about two feet had come loose from the spot welds. I don't see any way to re-spot weld the thin metal of the channel back, so I guess plug welding is the answer (unless somebody has a better way). So I have a twofold question, 1 is plug welding the best answer to my problem, and any suggestions on a mig/tig welder to do the job. I am fairly good at arc welding. And as much as I would like to purcahse a Hobart, Lincoln, or Miller welder I can't afford 3 grand for a tool for my hobby. So 2 any suggestions for a shade tree welder? Any suggestions or observations are welcome, Jimmie. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Don't know if this will do you any good but drilling the channel in a few spots and hitting it with a small rod and lower amperage should do the trick. That's assuming you've got access to a stick welder. If that isn't the case I'd be tempted to use a pop rivet and a heat gun to warm the rubber so you could work it around the head. Mine didn't go into the track and feed around....had to work it in with a blade, inch by brutal inch!!!
I've got an old-time stick welder....sprung for a mig w/gas.....great for occasional light work but I get a whole lot more use out of my stick or oxyacetylene. Kinda hard to justify having that kind of coin tied up in a machine unless you're using it on a regular basis.
Dave | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | pop rivet it back together, then smash the head down for windlace clearence. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hey guys, thanks for the input. I have an old Craftsman 110 volt stick welder that I bought years ago. It can use rod down to 3/16 so that is probably what I will do. I know this won't help now, but I used petroleum jelly on the windlace, and channel. Then the windlace just slipped right in. Jimmie. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Stick welding might make a mess. I went Wilbur's route and riveted them on. They can be installed after painting that way too. Good luck.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
