Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Ponchogl, Hanks custodian, Wickedbass, SWEET, FAST55), 24 guests, and 3 robots.
Topics128,009
Posts1,055,297
Members48,419
#165582 03/22/2007 10:41 PM
what kind of backing can/do you put behind the door panel, between the panel and door itself? just got my new door panels and headliner from Rod Doors and was thinking there should be some kind of backing like what comes on newer doors. also what kind of fabric do you use to cover panels? theres a design on the panel that would require the fabric too be moulded around the design. thanks in advance...
#165583 03/22/2007 11:00 PM
if you got those colored fancy molded things with embossed design on the surface, what ya see is what ya get, no backing or fabric intended
#165584 03/23/2007 12:48 AM
For the fabric, use tweed it forms really easy around shapes.
If your looking for some kind of vapor barrier just use heavy plastic sheeting.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#165585 03/23/2007 5:06 PM
I painted mine. Work? Don't know but they have yet to warp or wrinkle.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#165586 03/23/2007 9:27 PM
thanks for the comeback guys, I'll check with the local shops to see what they have.
Moderated by  ndkid275, Phak1
