1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 37 Member | | Member Joined: Dec 2006 Posts: 37 | what kind of backing can/do you put behind the door panel, between the panel and door itself? just got my new door panels and headliner from Rod Doors and was thinking there should be some kind of backing like what comes on newer doors. also what kind of fabric do you use to cover panels? theres a design on the panel that would require the fabric too be moulded around the design. thanks in advance... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you got those colored fancy molded things with embossed design on the surface, what ya see is what ya get, no backing or fabric intended
Bill | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | For the fabric, use tweed it forms really easy around shapes. If your looking for some kind of vapor barrier just use heavy plastic sheeting. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I painted mine. Work? Don't know but they have yet to warp or wrinkle. | | | | | Joined: Dec 2006 Posts: 37 Member | | Member Joined: Dec 2006 Posts: 37 | thanks for the comeback guys, I'll check with the local shops to see what they have. | | |
