5 members (dt235sd, Toadwart, Chip O, 2 invisible), 106 guests, and 1 robot.
Topics128,087
Posts1,055,998
Members48,430
#164989 11/26/2006 7:15 PM
I pulled my original wheel off to put on a wood steering wheel & noticed that my top steering column bearing is in bad shape. Are these hard to replace & where should I get one? Also, is there a lower bearing & should I relace it while I'm at it or is it harder to change? Thanks!
The lower bearing IS harder to change, but it often wears more than the top. If the linkage, mounting bolts, & turn signal stuff is removed the "mast jacket" or outside sheetmetal part of the column will slide up & off the steering shaft. Bad bearings can cause hard steering & shifter binding. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks, where would be a good place to find buy these?
bad bearings will also grind a groove in your shaft, i caught mine when it had worn more than half way thru the shaft. i forget where i got my new bearings as this happened more than twelve years ago. I might have got them from the Filling Station or Dan's Classic parts.
i love my dog's 1965 suburban.
Ordered them today from Chevy Duty, might be here tomorrow. I'm a little nervous about the bottom bearing but I'm sure I'll get it...thanks again!
HELP, I just opened it up & I dont know where the bottm bearing is, I have the turn signal & the 2 sheet metal "cups" completly off & I cannot see a bearing in there. How far down is it? I unscrewed a bolt with a screw head out of the bottom of the column & it released a sheetmetal sleeve with a white plastic sleeve, could this be where the bearing should be? It looks like someone has been in here before because of electrical tape. Any help? Thanks!
It is further down, on the engine side of the firewall. You will need to remove the mast jacket, there are two 1/4"(7/16" head) bolts just under the dash, then a clamp on the firewall side. Linkage if any must be disconnected. Brian
I just discovered it, thanks!!
Moderated by  ndkid275, Phak1
