1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#164922 11/14/2006 12:24 AM
Apprentice
Apprentice
Hi Guys
I am restoring my 1951 chevy styleline 4 door. I need to remove the door and window handles but i noticed that it is neerly impossible to do it without the tool. I have seen that fillingstation.com has it but it takes like 3 weeks to get stuff to canada. is there a way to do it without the tool, or can i make myy own tool.
Thx
Chaimv
#164923 11/14/2006 2:13 AM
I have always had good luck removing the clip by grinding a notch in a old hacksaw blade to form a hook. Then you can slip it in between the handle and the eschuteon and pull it out. Be sure and watch for where it lands as sometimes they get away
41,32,33
1949 Chevy 6400
1931 Chevy Firetruck
#164924 11/14/2006 3:16 AM
Quote
Originally posted by 31,32,33:
[ Be sure and watch for where it lands as sometimes they get away
41,32,33 [/QB]
I find the clip usually gets away. I've put a magnet on the hacksaw blade makeshift tool or make a almost complete loop on the end of a wire to pull the clip.
i love my dog's 1965 suburban.
#164925 11/14/2006 5:42 AM
I recently saw these tools hanging on a board in Advance Auto Parts and Auto Zone. Perhaps you have a parts store around that has the same. And not near as costly as ordering one from Eastwood or some catalog.
#164926 11/14/2006 8:31 PM
Anonymous
Unregistered
Anonymous
Unregistered
Huh ???? You just use a shop towel and slid the middle behind the handle and it will catch the end of the clip as you pull (holding tension with the other end)it to one side or the other.
come on you didn’t watch your dad did you?
#164927 11/17/2006 6:04 AM
Apprentice
Apprentice
Hi Guys
Tried your advice about the hacksaw makeshift tool, shop towel, hack i even purchased the special tool. I still have no luck removing the handles. nothing i used seems to cath the part of the clip. the little ends of the clip seem to be too deep inside the groove in the handle itself. am i doing something wrong or is there an easier way.
best regards
Chaimv
#164928 11/17/2006 2:43 PM
You sure it doesn't have a set screw hidden somewhere? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#164929 11/17/2006 4:54 PM
Apprentice
Apprentice
i checked and it does not have a screw
Thx
Chaimv
#164930 11/17/2006 5:15 PM
Somone might have glued it on(JB Weld), I have run across that before. Brian
#164931 11/20/2006 1:22 AM
Apprentice
Apprentice
i dont think that it is glued, i just cant seem to get anyhting to hook on to the clip to remove because the little ends are in pretty deeply in the handle. I dont particulary care for the clips because they are pretty readily available i just dont want to damge the hardware or the mechanism
Moderated by  ndkid275, Phak1
