3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#164444 06/17/2006 5:10 PM
Not truck related but could be. I recently drove the wife's 04 Malibu to CA and back and noticed that glare of the dash was reflected up onto the windshield. This was almost a day long problem making it impossible to see clearly through the glass and causing a bad case of eye fatique. Does anyone know of a product that can maybe be sprayed or wiped on the vinyl/plastic dash to reduce/eliminate the reflection factor without damaging the dash materials? Thanks in advance.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
How about a dash mat Bruce? They will protect the dash and cut the glare
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
I sure don't think you need armorall. as a tempory fix you could use wax and not rub it off??? The dash mat sounds good.
Had thought about the dash mat but figured it would probably cause the reflection also. The interior color is a light gray but would like to stay away from black or another dark color if possible. This is wifey's car and she can be fussy at times. Personally I like the dash mat.
Bruce
They sell anti-glare at most parts stores.
Applies to the inside of the glass.
I use it on my snowmobile helmet to cut the glare at nite.
Wilbur
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Thanks wilbur I'll look for this. I was thinking more along the lines of something for the dash itself and not the glass.
Bruce
Moderated by  ndkid275, Phak1
