0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Not truck related but could be. I recently drove the wife's 04 Malibu to CA and back and noticed that glare of the dash was reflected up onto the windshield. This was almost a day long problem making it impossible to see clearly through the glass and causing a bad case of eye fatique. Does anyone know of a product that can maybe be sprayed or wiped on the vinyl/plastic dash to reduce/eliminate the reflection factor without damaging the dash materials? Thanks in advance.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | How about a dash mat Bruce? They will protect the dash and cut the glare
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I sure don't think you need armorall. as a tempory fix you could use wax and not rub it off??? The dash mat sounds good. | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Had thought about the dash mat but figured it would probably cause the reflection also. The interior color is a light gray but would like to stay away from black or another dark color if possible. This is wifey's car and she can be fussy at times. Personally I like the dash mat.
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | They sell anti-glare at most parts stores. Applies to the inside of the glass. I use it on my snowmobile helmet to cut the glare at nite.
Wilbur | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Thanks wilbur I'll look for this. I was thinking more along the lines of something for the dash itself and not the glass.
