12 members (Otto Skorzeny, dt235sd, mason86, Bill Hanlon, MickeyP, 68ironhead, Greg_H, tclederman, Shade Baby, 3B, Charles in CA, 32Fordpuchoptop),
98
Mod | | | Forums66 Topics128,049 Posts1,055,649 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I have what is probably the original ash tray for my ’41, but ended up getting a replacement plastic handle. It did not come with any method of attaching it. The handle has two smooth plastic studs that protrude about 3/16” into the inside of the ash tray. What am I supposed to do with these? Some kind of push on clip?? Maybe heat them to a sort of mushroom shape?? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, heat mushroom them
Bill | | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 |
1941 AK named "PETEY" my buddy.
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Kip - Mine came with clips that push on the stud. You should be able to get them at your favorite hardware store. I'm sure youve seen them, they are just a rectangular piece of metal with a hole, usually used with sheet metal screws. I think they are called speed nuts, but not sure. George | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Once again you guys have come through. I think I’ll try the push on “speed nuts” first. If for some reason they don’t work I’ll go to melting. It’s always nice to know what others have tried before getting started. | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | You need those little one way push clips. That's what I used on mine. Found them at the hardware stores where they have all those drawers full of llittle oddball faseners. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Just what the truck needs, More oddball stuff. It’s just amazing how many non original things have turned up, kinda says something about a very forgiving and adaptable design | | |
