4 members (Patina 54, sron48, Otto Skorzeny, FAST55), 114 guests, and 2 robots.
Topics128,034
Posts1,055,440
Members48,422
#164269 04/07/2006 2:40 AM
I have what is probably the original ash tray for my ’41, but ended up getting a replacement plastic handle. It did not come with any method of attaching it. The handle has two smooth plastic studs that protrude about 3/16” into the inside of the ash tray. What am I supposed to do with these? Some kind of push on clip?? Maybe heat them to a sort of mushroom shape??
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#164270 04/07/2006 2:58 AM
yes, heat mushroom them
#164271 04/07/2006 3:44 AM
I agree with Bill...
1941 AK named "PETEY" my buddy.
#164272 04/07/2006 5:59 PM
Kip - Mine came with clips that push on the stud. You should be able to get them at your favorite hardware store. I'm sure youve seen them, they are just a rectangular piece of metal with a hole, usually used with sheet metal screws. I think they are called speed nuts, but not sure.
George
#164273 04/07/2006 10:38 PM
Once again you guys have come through. I think I’ll try the push on “speed nuts” first. If for some reason they don’t work I’ll go to melting. It’s always nice to know what others have tried before getting started.
#164274 04/08/2006 12:49 AM
You need those little one way push clips. That's what I used on mine. Found them at the hardware stores where they have all those drawers full of llittle oddball faseners.
#164275 04/08/2006 3:09 AM
Just what the truck needs, More oddball stuff. It’s just amazing how many non original things have turned up, kinda says something about a very forgiving and adaptable design
Moderated by  ndkid275, Phak1
