1 members (Gdads51), 84 guests, and 3 robots.
Topics128,139
Posts1,056,447
Members48,441
#164243 04/05/2006 5:32 AM
ajc
Offline
Junior Member
Junior Member
What is the interior color on my 64 called? it is a tan or champagne looking color. i would like to repaint the interior with rattle can paint, i think i can do a good job if i prep the metal correctly. are there some vendors who supply this color in rattle cans? thanks for any help you can provide.
-anthony
"Send lawyers, guns, and money." W.Zevon
#164244 05/21/2006 5:36 AM
Hi Anthony,
The original interior color is called "fawn", there is 2 different shades of fawn. The first color of fawn is for the '60-'62, and the'63-'66 trucks fanw is a another shade. One is a little lighter than the other, I can't remember which one is lighter or darker. :o
I do know a guy off of another board I visit, and he had bought the rattle can fawn color, and he redid the firewall on his '66, and it looks awesome!! He's over on Chevy Talk forum in the '60-'66 trucks page, he goes by the handle "Hilandr451".
There's another guy their too that redid the whole interior the same color on his '65, I believe his handle is "Chevrolet65".
I hope this helps.
David
My truck don't leak oil, it just marks its teritory.
#164245 05/21/2006 12:32 PM
ppg #22151 fawn,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#164246 05/21/2006 8:50 PM
ajc
Offline
Junior Member
Junior Member
thanks Dave and Brian. I have not had a chance to start work on the interior. Had to have the heads redone so I'm working on the engine compartment now. I guess I'm going to get it running correctly first then start on the interior.
thanks again to both of you,
-anthony
#164247 05/21/2006 9:54 PM
As far as getting the paint into an rattle can- If it doesn't require activator/harnder NAPA or your local paint store can put it into a pressurized can for a few bucks. When you mix paint with those ingrediates it begins to degrade immediately and isn't usable after a short while. If it does require that stuff, you can buy either a "perval spray system" refillable aerosol can.
Both are available at Harbor Freight and other vendors.
The Perval system uses disposible cans of comressed air that screw onto a jar that you put the paint into. The tops of the disposible cans have regular rattle can tips and that connect to the jar via a tube from the jar that plugs into a gasket at the bottom of the disposible can.
The refillable areosol can has a screw off lid and an air fitting so you can put the mixed paint into the can, pump it full of air with any pump=hand pump, compressor, gas station's compressor..., and then paint with it. The refillable aerosol can comes with extra tips.
Both work fine.
Moderated by  ndkid275, Phak1
